This is a short circuit protection circuit, I don't know if it is feasible, but through the simulation test, I found that it can effectively disconnect the power output at both 1 V voltage and 30 degrees voltage!If it is feasible, can it be added to the circuit, is the work of the circuit protected more effectively?
After the protection mechanism moves, it needs to turn off the power supply to be reset. There is another problem, that is, when the input voltage is below 1 volt, the circuit will automatically act and turn off the output!
