TL494 Kullanan Yüksek Güçlü Yüksek Verimli Buck Dönüştürücü Devresi
Features of TL494 IC
- Complete PWM Power-Control Circuitry
- Uncommitted Outputs for 200-mA Sink or Source Current
- Output Control Selects Single-Ended or Push-Pull Operation
- Internal Circuitry Prohibits Double Pulse at Either Output
- Variable Dead Time Provides Control Over Total Range
- Internal Regulator Provides a Stable 5-V
- Reference Supply With 5% Tolerance
- Circuit Architecture Allows Easy Synchronization
Components Required
- TL494 IC - 1
- TIP2955 Transistor - 1
- Screw Terminal 5mmx2 - 2
- 1000uF,60V Capacitor - 1
- 470uF,60V Capacitor - 1
- 50K,1% Resistor - 1
- 560R Resistor - 1
- 10K,1% Resistor - 4
- 3.3K,1% Resistor - 2
- 330R Resistor - 1
- 0.22uF Capacitor - 1
- 5.6K,1W Resistor - 1
- 12.1V Zener Diode - 1
- MBR20100CT Schottky Diode - 1
- 70uH (27 x 11 x 14 ) mm Inductor - 1
- Potentiometer (10K) Trim-Pot - 1
- 0.22R Current Sense Resistor - 2
- Clad Board Generic 50x 50mm - 1
- PSU Heat Sink Generic - 1
- Jumper Wires Generic - 15
