Yüksek Verimli Buck Dönüştürücü
TL494 Kullanan Yüksek Güçlü Yüksek Verimli Buck Dönüştürücü Devresi
Features of TL494 IC
  • Complete PWM Power-Control Circuitry
  • Uncommitted Outputs for 200-mA Sink or Source Current
  • Output Control Selects Single-Ended or Push-Pull Operation
  • Internal Circuitry Prohibits Double Pulse at Either Output
  • Variable Dead Time Provides Control Over Total Range
  • Internal Regulator Provides a Stable 5-V
  • Reference Supply With 5% Tolerance
  • Circuit Architecture Allows Easy Synchronization
Note! Most of the internal schematic and operations description is taken from the datasheet and modified to some extent for better understanding.
Components Required​
  1. TL494 IC - 1
  2. TIP2955 Transistor - 1
  3. Screw Terminal 5mmx2 - 2
  4. 1000uF,60V Capacitor - 1
  5. 470uF,60V Capacitor - 1
  6. 50K,1% Resistor - 1
  7. 560R Resistor - 1
  8. 10K,1% Resistor - 4
  9. 3.3K,1% Resistor - 2
  10. 330R Resistor - 1
  11. 0.22uF Capacitor - 1
  12. 5.6K,1W Resistor - 1
  13. 12.1V Zener Diode - 1
  14. MBR20100CT Schottky Diode - 1
  15. 70uH (27 x 11 x 14 ) mm Inductor - 1
  16. Potentiometer (10K) Trim-Pot - 1
  17. 0.22R Current Sense Resistor - 2
  18. Clad Board Generic 50x 50mm - 1
  19. PSU Heat Sink Generic - 1
  20. Jumper Wires Generic - 15
Parts-List:
  1. TL494 IC - 1
  2. IRFP250 MOSFET - 1
  3. Screw Terminal 5X2 mm - 2
  4. 1000uF, 35V Capacitor - 1
  5. 1000uF,63V Capacitor - 1
  6. 50K, 1% Resistor - 1
  9. 3.3K, 1% Resistor - 1
  11. 0.1uF Capacitor - 1
  12. MBR20100CT Schottky Diode - 1
  13. 150uH (27 x 11 x 14) mm Inductor - 1
  14. Potentiometer (10K) Trim Pot - 1
  15. 0.22R Current Sense Resistor - 2
  16. Clad Board Generic 50x 50mm - 1
  17. PSU Heat Sink Generic - 1
  18. Jumper Wires Generic - 15
  • IC TL494 PWM Controller - 1
  • IRFZ44N MOSFET - 1
  • 220 uH Inductor - 1
  • LM358 Op-amp - 1
  • MBR20100CT Diode - 1
  • 5.08mm Screw Terminal - 2
  • 1000uF,25V Capacitor - 2
  • 1000uF,63V Capacitor - 1
  • 2.2nF Capacitor - 1
  • R560 Resistor - 2
  • 2.2K Resistor, 1% - 2
  • 4.7K, 1% Resistor - 1
  • 10K, 1% Resistor - 6
  • 50K Resistor - 1
  • 10K Trim-Pot - 1
  • Cladboard for PCB
