TV Led test devresi
Solid State LED Bulb Circuit with Dimmer Control using IC IRS2530D​
A simple yet efficient mains transformerless solid state LED controller circuit is explained here using a single full bridge driver IC IRS2530D.
Introduction​
Normally LED control circuits are based on buck boost or flyback principles, where the circuit is configured to produce a constant DC for illuminating an LED series.
The above LED control systems have their respective drawbacks and the positives in which the range of operating voltage and the number of LEDs at the output decide the efficiency of the circuit.
Other factors like whether the LEDs are included in parallel or series or whether they need to bedimmed or not, also affects the above typologies.
These considerations make these LED control circuits rather dicey and complicated.The circuit explained here employs a different approach and relies on a resonant mode of application.
Though the circuit does not provide direct isolation from the input AC, it has the features of driving many LEDs with current levels as high as 750 mA. The soft switching process involved in the circuit ensures greater efficiency to the unit.
How the LED Controller Functions​
Basically the mains transformerless LED control circuit is designed around the fluorescent lamp dimmer control IC IRS2530D. The circuit diagram shows how the IC has been wired up and how its output has been modified for controlling LEDs in place of the usual fluorescent lamp.
The usual preheating stage required for a tube light utilized a resonant tank which is now effectively replaced by a LC circuit suitable for driving LEDs.Because the current at the output is an AC, the need of a bridge rectifier at the output became imperative; this makes sure that current is continuously passing through the LEDs during every switching cycle of the frequency.
The AC current sensing is done by the resistor RCS, placed across the common and the bottom of the rectifier.This provides an instant AC measurement of the amplitude of the rectified LED current.The DIM pin of the IC receives the above AC measurement via the resistor RFB and capacitor CFB.
This allows the dimmer control loop of the IC to keep track of the LED current amplitude and regulates it by instantaneously varying the frequency of the half bridge switching circuit, such that the voltage across the LED maintains a correct RMS value.
The dimmer loop also helps to keep the LED current constant irrespective of the line voltage, load current and temperature changes.Whether a single LED is connected or a group in series, the LED parameters is always maintained correctly by the IC.
Alternatively the configuration may also be used as a high current transformerless power supply circuit.
Şema bileşenleri. Eh, 555 zamanlayıcı ve çemberleme ile ilgili herhangi bir sorun olmamalı, burada her şey standart. Alan etkili transistör, yüksek voltajlı bir n-kanaline ihtiyaç duyar. Yazar IRF830 kullandı. ancak 2N60 ve 4N60 gibi transistörlere daha fazla voltaj marjına sahip olduklarını ve akımın devremiz için çok önemli olmadığını tavsiye ediyor.
Bobin, bir ferrit halter üzerine sarılır, tel 0.15, bobinin endüktansı 800 ila 1000 μH arasındadır. Demir tozu halkalarına veya bir ferrit çekirdek üzerine sarılabilir. Devamı ektedir.
Eki Görüntüle 31173
S/NQtyValueDescriptionPartsRemarks
11100pFCeramic CapC6
22104/50VMylar CapC3, C5
31222/50VMylar CapC4
41220uF/16VElectrolytic CapC2
51470uF/16VElectrolytic CapC1
614.7uF/400VElectrolytic CapC7
741N4007Gen Purpose Diode, 1 AD1, D2, D3, D4
81FR107Fast Rect DiodeD5
91IFR840N-Channel Enhancement MOSFET (HEXFET); 100V; 28A; 0,077OhmQ2
101BC547NPN TransistrorQ1
111***Resistor 1/4WR3to test via VR
12110KResistor 1/4WR2
1311KResistor 1/4WR1
141220KResistor 1/4WR5
1512K2Resistor 1/4WR6
1614R7Resistor 1/4WR4
17118K/2WResistor 2WR7Observe
1817809TO-220 VregulatorIC1
191NE555IC555 TimerIC2
201100uHINDUCTORL1Custom Made
212MKDSN1,5/2-5,08Conn Phoenix TerminalX1, X2
Eki Görüntüle 31174
Backlight LED Tester Led tv led test devresi aynı zamanda zener test devresi olarak kullanılabiliyor.
(150-250V) DC-DC dönüştürücü devresi​
Çeşitli hibrit cihazlar (yani yarı iletkenlerin ve vakum tüplerinin aynı anda çalıştığı tasarımlar) geliştirilirken, genellikle düşük voltajlı bir kaynaktan (9...12 V) yüksek anot besleme voltajı (150...250 volt) elde etmek gerekir.
Bunu yapmanın en kolay yolu, endüktif enerji depolama aygıtı ile trafosuz bir gerilim dönüştürücü kullanmaktır.
Bu tip DC-DC dönüştürücüler için MAX1771, MC34063 ve benzeri çeşitli özel IC çipleri kullanılabilir. Ancak çoğu geliştiriciye göre tercih edilen seçenek MAX1771 IC'dir. Bu çip, çeşitli yapılandırmalarda yüksek verimlilik elde etmek için alışılmadık bir darbe genişlik modülasyonu (PWM) şemasını kullanır ve dahili yük akımı sınırlayıcısının ek avantajına sahiptir.
Ayrıca MAX1771 harici frekans ayar elemanlarına ihtiyaç duymaz, geniş bir besleme voltajı aralığına (2...16,5 V), yüksek (300 kHz'e kadar) saat frekansına ve harici bir MOSFET transistörünü kontrol etmek için dahili bir sürücüye sahiptir.
Yüksek gerilimli DC-DC dönüştürücünün şeması Şekil 1’de gösterilmiş olup, veri sayfasında verilen konfigürasyondan pratik olarak hiçbir farkı yoktur.
Şekil 1 MAX1771 üzerindeki yüksek gerilimli DC-DC dönüştürücünün şematik diyagramı
Modül, 300 kHz'e kadar anahtarlama frekansında çalışan ve minyatür yüzeye monte bileşenlerin kullanımına olanak tanıyan MAX1771 DC-DC kontrolörüne dayanmaktadır.
Çıkış voltajı R4 potansiyometresi kullanılarak seçilir ve 150...250 V DC aralığındadır. IRF740A kullanıldığında 180 V çıkış geriliminde maksimum çıkış akımı en az 50 mA'dir ve maksimum çıkış akımını bir miktar artırmanız (veya verimliliği iyileştirmeniz) gerekiyorsa transistörü IRF644PBF ile değiştirmelisiniz.
MAX1771 IC'nin harici bir N-kanal MOSFET'i kontrol ettiğini ve bir endüktör ve hızlı bir diyot yardımıyla yüksek bir voltaj oluşturulduğunu belirtelim. Cihazın yüksek verimliliğinin sağlanması için MOSFET transistörünün düşük RDS'ye, diyotun çok hızlı (Trr < 50 ns) ve kapasitörlerin düşük ESR'ye sahip olması gerekir. 50 mA'den büyük çıkış akımları için, L1 indüktörü yaklaşık 2 A'lik maksimum sürekli akım için derecelendirilmelidir. EPCOS B82479 gibi indüktörler bu spesifikasyona uygundur ve bu devrede çok iyi çalışır.
Eğer devrenizin yeterince stabil olmadığını düşünüyorsanız (örneğin elinizi yaklaştırdığınızda bobinden ıslık sesi duyuyorsanız veya çıkış voltajı değişiyorsa), o zaman FET'in gate terminalinin etrafına bir ferrit boncuk yerleştirmelisiniz.
Şekil 2’de elemanların dizilimi ile birlikte bir baskılı devre kartı örneği gösterilmektedir. Kartın boyutları yaklaşık 4 cm x 3 cm’dir.
Şekil 2 MAX1771 tabanlı DC-DC dönüştürücünün baskılı devre kartı.
Kartın arka tarafında, ön taraftaki toprağa birkaç delik aracılığıyla bağlanan topraklama düzleminin çoğaltılmasını görebilirsiniz. Her bir via genellikle birkaç yüz mA'i kaldırabilir ve güç bileşenlerinden 2 A'ya kadar akım geçebildiğinden, toprağa iyi bir düşük empedanslı yol sağlanmalıdır. Arka tarafta neredeyse hiç sinyal izi bulunmadığından topraklama yüzeyi tek bir düzlemden oluşmaktadır.
Verilen yüksek gerilimli DC-DC dönüştürücünün MAX1771 IC ve IRF740A transistörü üzerindeki verimi 180 V çıkış voltajı ve 50 mA yük akımında (Pout = 9 W) yaklaşık %74'tür.
Daha pahalı olan 2SK3772 kullanıldığında verimlilik önemli ölçüde artıyor ve verimlilik zaten %87'ye ulaşıyor, üstelik 130 mA çıkış akımıyla (Pout = 23,4 W).
