mp3 player product tool 5.11
In PC,Click "Start"-"Procedure"--"MP3 Player Product Tools"-"Product Tool" option,Run the program, press yes to produce the list.
then select one of the firmwares you have download,press"Replace"
press "yes" to replace the firmware
Then the tool interface will be opened, please connect the mp3 player to your pc. As the tool can identify only one USB port each time, so you can only insert only one USB device into the USB port, if no connection to any device, the tool will prompt "0 MP3 Player were detected ". In this case "Download" buttons are invalid.If succeed in identifying the USB port, the tool shows the lamp of the USB port. After succeed completed the USB port configures, as follow picture:
After the tool successfully identified the USB port, press the "download",and wait for some minutes
when you see the follow picture,turn off you mp3 player,disconnect it form pc,then turn it on,wait for 20 sec,if you still can't use it,turn it off,and turn on again.
NOTE:If your mp3 player still can't work with current firware, try the other firmware and repeat the above steps.
  • ProductTool511.rar
    5 MB · Görüntüleme: 372
  • mp4help.rar
    147,8 KB · Görüntüleme: 127
How to convert to the .amv video to be playable by the mp4 player ?
Here are the instructions on how to convert to an .AMV video file using the MP3_Player_Utilities_3_68_www_mympxplayer_org.rar which can be downloaded here.
1. Open "AMV Convert Tool" from the [Start] --> [Programs] --> [MP3 Player Utilities 3.68] menu.
2. Click on the [Add File] icon on the top right of the AMV Video Convert Tool screen.
3. Select the file you want to convert then press the [Open] button.
4. You will now see your file below in the queue.
lg.php
5. Select the file you want to encode in the queue list below. Then press the [Settings] button on the right hand side to change your encoding settings. If you don't select the file, the [Settings] button is greyed out and you can't click on it.
6. For "screen width and height", change it to "128x96" if you have a 1.5" screen player, or "96x64" if you have a 1.2" screen player.
Make sure "Frames per second" and "image quality" is set to "high".
NOTE: If you have problems with 'Format Error" messages during playback on your player, change the "image quality" to "medium" instead.
Tick "Try another codec" if you have errors trying to encode a video to .AMV, this might fix it.
Click on [OK] button.
7. Click on the "AMV Path" button on the top right to select where you want the new .AMV file to be outputted to.
8. Click on the "Begin" button to start encoding.
9. It will now convert your video and show you the progress down the bottom.
10. If successful, you will the following prompt. If the convert fails, try putting the tick in "Try another codec" option box in your [Settings].
Hope this helps you all out.
  • How to_ Convert to .AMV using the MP3 Player Utilities 3.68.zip
    123,5 KB · Görüntüleme: 4
5,11 kururken dosya hatası veriyor
benim elimdeki mp4 firmware sini 9.xxx
tümünü denediysemde olmadi
chip atj2091n
samsung 813
QY-781FV2 2006-12-31
LÜTFEN YARDIM EDİNNNNNNNNNNN FİRMWARE ARIYORUM
Programda eksık dosya diyor 5.11 20070011.mcs gibi
biirde sende alta yazılı olan cıhazın firmwaresi bulunurmu
chip atj2091n
samsung 813
qy-781fv2 bu bilgiler var elimde
yeterlimi
