LM3886 ses amplifikatör devreleri
Circuit audio power amplifier of 68 watts using lm3886
The lm3886 is an integrated circuit very used in projects of audio amplifiers by that it can be found with more easiness.
see that the circuit should be fed by source symmetrical good filtered of + 34 and – 34 volts. R2 and L1 is a resistor of 10 ohms / 2watt coiled with 10 to 12 you exhale of enameled thread AWG 20. The circuit integrated lm3886 is a component easy of being found at the electronics stores, for that he is used in several projects of potency audio, some exist circuits with linked lm3886 in bridges for potencies of up to 150 watts. For most information on the assembly of that circuit, I suggest that sees the datasheet of the lm3886 in the site of the national semiconductors. With the information of the leaf of data you can adapt the circuit with lm3886 your needs.
suggestion of printed circuit board for assembly of the power amplifier
Board for assembly seen beside the components power amplifier lm3886
It lists of components for assembly of the power amplifier
R1 10K Ohms
R2 10 Ohms 2W sees text
R3 10 Ohms
R4 47K Ohms
R5 220K Ohms
R6 10K Ohms
R7 100K Ohms
C1 100NF
C2 100NF
C3 100NF
C4 100UF
C5 100UF
C6 4,7UF
C7 100UF
C8 1UF
L1 0,7uH sees text
Power Amplifier with LM3886
LM3886 entegresi ile yapılmış farklı bir devre daha
This is 100W LM3886 power amplifier is based on the PA100 parallel amplifier detailed in National Semiconductor's application note - AN1192. Since my DIY speaker is 4-ohm and somewhat difficult to drive, I want to have a more powerful amplifier to match with it. Therefore I designed this amplifier which uses two LM3886 per channel, in parallel circuit. This amp can deliver about 50W into a 8-ohm speaker and 100W into a 4-ohm speaker. This is a stereo amplifier and therefore 4 LM3886s are used. The LM3886 circuit is in a non-inverted configuration, so the input impedance is determined by the input resistor R1, i.e. 47k. The 680 ohm and 470pF resistor capacitor filter network is used to filter out the high frequency noise at the RCA input. The 220pF C4 and C8 capacitors are used to shot out the high frequency noise at the LM3886 input pins. I used high quality audio grade capacitors at several locations: 1uF Auricap at the input for DC blocking, 100uF Blackgate for C2 and C6, and 1000uF Blackgate at the supply filter.
The PCB is designed in a way that the power ground is separated from the signal ground, as you can see from the below layout. The signal ground is located in the middle and surrounded by the power ground. There is a thin trace near C5 connecting them. The PCB layout is done by using PADS PowerPCB 5.0. I think it is a powerful layout software. After finished the layout, I send it to a PCB manufacturer in HK to make the PCB. After the PCB is made, I found some of the drill holes are not large enough.... I have to make it bigger manually.
Finished PCB.
The 20k and 1k resistors are hand matched to 0.1%. For the output resistors, I used six 0.5W 1% 1ohm resistors in parallel per 3886 output instead of one 3W resistor because 3W 1% resistors are hard to find.
I used the insulated version - LM3886 TF, so that I can mount it directly to the case and heat sink with thermal compound.
Coupling capacitor is Auricap 1uF 450V. I used this high quality capacitor because it is in the main signal path.
The HF filter capacitors are Silver Mica 47pF and 220pF.
The power supply filter used is Blackgate 1000uF 50V.
C2 and C6 are Blackgate 100uF 50V. For better result, the bi-polar version should be used. However I am not using it because the bi-polar blackgate is too big to fit into my PCB.
The 680 ohm + 470pF filter network is installed at the RCA. This help filtering the high frequency noise before it gets onto the board.
The WIMA 0.1uF supply decoupling capacitors are soldered directly on the pins of LM3886 at the back of the PCB. This helped to remove some high frequency noise.
The 3886 are mounted on a 3/8 inch aluminum plate then to the case. Outside of the case I used 3 PC CPU heatsinks. I used Arctic Silver thermal compound between the aluminum layers to improve heat conductivity.
With all these big heatsinks, it only get slightly warm when listen at normal volume.
The power supply used is a regulated power supply. I used 10000uF per rail before the LT1083 regulator. After the regulator, I have 100uF on the regulator board. The advantage of using regulator is that the power supply ripple voltage is removed. If power regulation is not used, I can hear very little 50/100Hz hum from the speaker.
LM3886 üzerindeki amplifikatör devresi
LM3886'nın girişine sabit bir bileşen geçirmeyen izolasyon kapasitörü C1 film olmalıdır.
Devrenin çıkışında, Zobel R7C11 devresi, R6 direnci üzerine sarılmış indüktör L1 ile birlikte bağlanır. Bu elemanlar, dinamik kafanın bobininin endüktansının parazitik etkisini ve hoparlör sistemini amplifikatöre bağlayan bağlantı tellerindeki paraziti bastırır.
R6, R7 dirençleri 2 watt olmalıdır. R6'nın üstünde, bakır vernikli bir telle (0,6-1 mm çapında) 6-10 tur (direnç kutusu tamamen dolana kadar) sarmak gerekir. Telin ve lehim uçlarını R6 direncinin dallarına doğru soyun.
C2 (seramik) hariç tüm polar olmayan kapasitörler film olmalıdır.
Güç kaynağı hakkında ayrı bir kelime söylenmelidir. İki kutuplu olmalı ve yeterli güce sahip olmalıdır.
Kaynak bir transformatör üzerinde yapılacaksa, ikincisi kanal başına en az 50 W olmalı ve iki ikincil sargıya veya ortalama bir muslukla bir ikincil sargıya sahip olmalıdır. Transformatörün sekonder sargılarının 8 Ohm'luk bir yükte voltajı 28V + 28V AC'den fazla ve 4 Ohm'luk bir yük için 20V + 20V'dan fazla olmamasını öneririm. Örneğin, redresörün çıkış kapasitörlerinde 20V + 20V'yi düzelttikten sonra + 28V ve -28V DC elde edersiniz (1.41 ile çarpın).
Blokaj tanklarının kavşağında bir yakınsama noktası bulunur. OOS kapasitans devresi, bir film kondansatörü tarafından şöntlenen iki karşı seri elektrolitten oluşur. Giriş, güç devrelerinden mümkün olduğunca uzaktadır. Böyle bir demet ses için en uygun olarak kabul edilir.
  • LM3886-Star-Classic.rar
    16,6 KB · Görüntüleme: 54
    6,9 KB · Görüntüleme: 62
Özellikler:
Frekans aralığı: 2 - 70000 Hz
Nominal çıkış gücü: 40W/8ohm
Nominal çıkış gücü: 56W/4ohm
8 ohm yükte sönümleme faktörü: 200'den fazla
Sinyal-gürültü oranı, 600 ohm: 96 dB'den büyük (ağırlıksız)
1-40 W güçte 20-20000 Hz aralığında THD: %0,05'ten az / 8 ohm
performans ölçüm sonuçları:
20 - 20000 Hz aralığında kazanç: 30 ( +29 dB)
Maksimum giriş voltajı: 0,775 V (ampl.)
-3 dB bant genişliği: 1.5 - 90.000 Hz
20-20000 Hz aralığında frekans yanıtı eşitsizliği: 0,2 dB'den fazla değil
20-20000 Hz aralığında PFC: doğrusal
20 kHz'de faz kayması: -18°
50-20000 Hz aralığında grup gecikmesi: kalıcı
4 ohm yüke kısa süreli güç: 68 W (rms)
Önerilen çalışma gücü: 30 W'a kadar (rms)
LM3886 amplifikatör (50 W/4 Ohm)​
Amplifikatör Özellikleri:
Çıkış Gücü: 50W/Kanal (Soğutucu Alanına Göre Belirlenir);
Giriş empedansı (ALPS RK27 10k üzerinde ses kontrol tertibatı ile): 10 kΩ;
Harmonik bozulma (THD+N): %0,001 (1 kHz, çıkış voltajı 29Vp-p, 6,8 ohm yükte);
İntermodülasyon Bozulması (IMD): -98 dB (19+20 kHz, 17Vp-p'den 6.8 ohm'a);
20-20000 Hz frekans bandında çıkış empedansı: <0,1 ohm (8 ohm yük için sönümleme faktörü ~80)
Besleme devresi +/- 30V (filtrede 2x20000uF) kullanabilirsiniz.
ÖlçekTDA7294LM3886SB PCI128
Frekans yanıtı eşitsizliği (40 Hz'den 15 kHz'e kadar), dB:​
+0.16, -0.17+0.20, -1.84+0.10, -0.15
Gürültü seviyesi, dB (A):​
-87,5-83.9-87,5
Dinamik aralık, dB (A):​
84.482.987.3
Harmonik bozulma, %:​
0.00590.00500.0053
İntermodülasyon bozulması, %:​
0.0280.0440.027
IC9 10uF kondansatör ses girişi olup potansa girmektedir.
LM3886TF Köprülenmiş devre versiyonu Devrede SMD IC yerine bu entegrelerden birini kullanabilirsiniz. TL072, NE5532, RC4558 ,TL082
