400 Watts mono amplifier using Toshiba 2SC5200 Transistor
components ᐅ1. 8×2SC5200 (PNP) Transistor.
2. 1×C5198 (NPN) Transistor.
3. 1×A1941 (PNP) Transistor
4. 1×TIP42 (PNP) Transistor.
5. 2×C2229 (NPN) Transistor.
6. 2×A1015 (PNP) Transistor.
7. 2×10pF (10) capacitor 100v.
8. 2×470pF (471) capacitor 100v.
9. 1×0.1uF (104) capacitor 250v.
10. 2×100uf capacitor 50v.
11. 1×2.2uf capacitor 50v.
12. 8×0.33Ω (BPR56) resistor 5w.
13. 1×10Ω resistor 5w.
14. 1×4.7kΩ resistor 1w.
15. 2×100Ω resistor 1w.
16. 1×10Ω resistor 1w.
17. 8×10Ω resistor 1/2w.
18. 1×33Ω resistor 1/4w.
19. 3×150Ω resistor 1/4w.
20. 1×1kΩ resistor 1/4w.
21. 1×10kΩ resistor 1/4w.
22. 2×68kΩ resistor 1/4w.
23. 1×33kΩ resistor 1/4w.
24. 2×3.3kΩ resistor 1/4w.
25. 3×1N4007.
26. 1×Zener Diode 24 volt 1w or 1/2w.
27. 1×GJB2510. (25 Amp)
28. 2×10000uf 80V capacitor.
29. 1×5uH coil (1.6mm/ 16 gauge copper wire)
30. 1×2 pin connecter base 2.54 mm.
31. 5×6.3 mm vertical PCB terminal
32. 1×100k single turn potentiometer.
