This is the circuit of Op-AmpMicrophone Preamplifier using a single power supply, this circuit suitable for dynamic or electret microphones. Nothing too special here. The Schematic is shown using a dynamic microphone, for use with an electret a pair of suitable biasing resistor is required to power the electret microphone.
Note:
The design is a standard non-inverting design, the input is applied to the non-inverting input of the op-amp, which is pin 3 in most cases. The input impedance is 23.5k, the overall voltage gain is determined by R2 and R1according to the following formula:
Vo = (R2 / R1) + 1
With the values of R2 and R1 on the diagram of the voltage gain (for mid band, 1kHz) is approximately 23x or 27.2dB.
Note:
- use a capacitor with voltage 25volt or more
- so that the sound produced maximal use supplay good voltage, with output of 18 volts max
- If the desired strengthening of the different, you can change the value of R1 or R2
Vo = (R2 / R1) + 1
