Mini Yüksek Gerilim Üreteci (Mini High-Voltage Generator)
Warning!
If you build the version without the voltage doubler and measure the output voltage with your multimeter, you’ll see a lower value than stated. This is due to the fact that the waveform is a long way from being a sinewave, and multimeters have trouble interpreting its RMS (root-mean-square) value. However, if you have access to an oscilloscope capable of handling a few hundred volts on its input, you’ll be able to see the true values as stated. If you’re still not convinced, all you need do is touch the output terminals…
To use this project to protect the handle of your beach bag or your attachecase, for example, all you need do is fix to this two small metallic areas, quite close together, each connected to one output terminal of the circuit. Arrange them in such a way that unwanted hands are bound to touch both of them together; the result is guaranteed! Just take care to avoid getting caught in your own trap when you take your bag to turn the circuit off!
çıkış voltajı 45 ila 190 V arasında değişen 5 W'lık bir yükseltici dönüştürücü oluşturmak için bir devre tasarımı bulunmaktadır. Ayrıca, diğer çıkış voltajları için dönüştürücü elemanlarının hesaplanmasına yönelik formüller verilmiştir.
