Amplifikatör Şemaları Arşivi
Amplificador Micron 50 S
60W/8Ω 85W/4Ω ±25 a ±35Vcc
  • PCB.pdf
    16,5 KB · Görüntüleme: 24
  • LayOut.pdf
    29,4 KB · Görüntüleme: 26
Amplificador Accuphase E 210 (Clone)
150 W/8Ω 250W/4Ω
  • E210-amp-schematic.rar
    671,3 KB · Görüntüleme: 31
DRIVER LME49811
• Input sensitivity: 0.88 V (137 W / 8 Ohm, THD+N = 0.1%)
0.91 V (145 W / 8 Ohm, THD+N = 1%)
• Input impedance: 15 kOhm
• Continuous output power: 137 W into 8 Ohm (THD+N = 0.1%)
145 W into 8 Ohm (THD+N = 1%)
220 W into 4 Ohm (THD+N = 0.1%)
233 W into 4 Ohm (THD+N = 1%)
• Peak/music power: 218 W into 8 Ohm (THD+N = 10%)
(DC supply voltage ±56.8 V) 175 W (8 Ohm, THD + N = 1%)
165 W (8 Ohm, THD + N = 0.1%)
395 W (4 Ohm, THD + N = 10%)
316 W (4 Ohm, THD + N = 1%)
299 W (4 Ohm, THD + N = 0.1%)
• Power bandwidth: 2.1 Hz to 125 kHz (50 W / 8 Ohm)
• Slew rate: 26.7 V/µs
• Risetime: 2.4 µs
• Signal to noise ratio: > 94 dB (linear, B = 22 Hz to 22 kHz)
(reference 1 W / 8 Ohm) > 97 dBA
• Harmonic distortion plus noise: 0.0033% (1 kHz, 1 W / 8 Ohm)
(B = 80 kHz) 0.0006% (1 kHz, 50 W / 8 Ohm)
0.006% (20 kHz, 50 W / 8 Ohm)
0.0047% (1 kHz, 1 W / 4 Ohm)
0.0009% (1 kHz, 100 W / 4 Ohm)
0.009% (20 kHz, 100 W / 4 Ohm)
• Intermodulation distortion: 0.002% (1 W / 8 Ohm)
(50 Hz : 7 kHz = 4 : 1) 0.0009% (50 W / 8 Ohm)
0.003% (1 W / 4 Ohm)
0.0026% (100 W / 4 Ohm)
• Dynamic IM distortion: 0.0033% (1 W / 8 Ohm)
((3.15 kHz square wave) + 0.0022% (50 W / 8 Ohm)
15 kHz sine wave 0.0045% (1 W / 4 Ohm)
0.0027% (100 W / 4 Ohm)
• Damping factor: 560 (1 kHz / 8 Ohm)
311 (20 kHz / 8 Ohm)
• Efficiency: 70.6% (8 Ohm, THD+N = 0.1%)
(DC supply) 72.5% (8 Ohm, THD+N = 1%)
68.5% (4 Ohm, THD+N = 0.1%)
70.5% (4 Ohm, THD+N = 1%)
• DC protection: +0.55 V / -0.86 V
• DC output offset: 0.2 mV (max. 0.6 mV)
• Switch-on delay: 6 s
  • LME49811.zip
    724,6 KB · Görüntüleme: 23
Ne gibi birdestek bekliyorsunuz yardımcıolim size elimden geliyorsa tabi
Web sitemizin açık kalması için gerekli olan masrafları var ayrıca daha büyük alan gerekiyor host kısmında bu tür masrafları tek karşılıyorum ve son zamanlarda zamlar ile beraber yormaya başladı ya ürün satışı yada bir sponsor olabilir ama bir çok yere firmalara mail attım ama cevap verende olmadı devam ettiğim yere kadar giderim gitmediği yerde bırakırım çokta kasmaya gerek yok diye düşünüyorum.
ayhan can
Özelden telini yazarmısın kardeşim
AMP G110​
Kılavuz dosyasına göre, bu amfi 70'lerde yapılmış. O dönemdeki transistörler, IC'den sonra özel bir öğedir.​
OCL 150 Watt'tan 400 Watt'a​
Hesaplamalara göre, eğer besleme bu kadar yükselebilirse, o zaman bu amplifikatör ( 60*0.65)² / 4 = 380Watt'a kadar güç üretebilecektir. bilgi için buradaki 0.65 rakamı bu amfinin verim sayısı sanırım %65 civarındadır.
SANSUI A80 HAKKINDA​
Sansui, 80-90 yıllarında Endonezya'da ünlü olan Japon yapımı bir Güç Amplifikatörü markasının adıdır
Bu gücün üretici tarafından 65 watt'a kadar güç verebildiği söyleniyor. Benim hesabım, eğer güç kaynağı 54V ise ve bu amfinin verimi %60 ise ve kullanılan hoparlörler 4 Ohm civarındaysa, o zaman şu rakamlar bulunacaktır:
P Çıkış= ( 54*0.6)²/8 = 131Watt. Bu 131W rakamı, Güç Amplifikatörü tarafından maksimuma çıkarıldığında elde edilebilecek maksimum sayıdır.
AÇIKLAMA​
ZD01, 20V'luk bir zenerdir. Hala 20V voltajda çalıştığı sürece başka bir numara ile değiştirebiliriz.
Bu isimsiz D01'i 1N4148 ile değiştirebiliriz.
TR13, aynı PNP tipi olduğu sürece diğer 2 transistör numarasına dönüştürülebilir. Uygulanabilecek transistör örnekleri şunları içerir: 2SA564.
TRANSİSTÖR ORTAM AYARLARI
Bu amplifikatörü daha verimli hale getirmek ve küçük seviyelerde çalışırken aşırı ısınmaması için üretici, TR25 ve TR27 transistörlerinin emitörleri arasındaki voltajın 3,3 miliVolt'luk bir potansiyel fark olması için trimpot VR01'i döndürme talimatı verdi.
Necati9
İyi günler hocam. Elimde 12 adet hoparlör 1 adet subwoofer var. Ben bunları 3'er li gruplar halinde 4+1(5+1 de olabilir hangisini yapmak daha mantıklı olursa tecrübenize güveniyorum) ses sistemi haline getirmek istiyorum. Hoparlörlerin 4 tanesi 4 ohm 5W, geriye kalanları 8 ohm 10W, subwoofer da 4 ohm 30W. Bütçe dostu ses kalitesi iyi olan ton bas kontrolü yapılabilen PCB çizimi olan devre şeması önerebilir misiniz. Henüz şematik çizimi olan şemaları anlayamıyorum. Güç kaynağı olarak da 12-30V luk 3 çıkışlı trafo veya 30V 3A DC güç kaynağı kullanabilirim.
