20 LEDS 0 TO 20V BAR-GRAPH VOLTAGE METER USING LM3914
0 – 20V LED Voltmeter project displays the voltage of the source using 20 LED’s. This project is based on the famous LM3914 IC from National Semiconductor.
Power Supply Input: 5 VDC Max @ 30 mA in DOT mode and 300 mA in BAR mode
Specifications
  • Output: 20 LED’s
  • Range selectable with onboard preset
  • 2 Types of display Bar and Dot selectable by a jumper
  • Berg connector for connecting power & voltage in
  • Four mounting holes of 3.2 mm each
  • PCB dimensions 40 mm x 145 mm
Resimler ektedir.
  • 0-20_DOT_Volt_Meter_Doc.pdf
    157,6 KB · Görüntüleme: 91
    44,6 KB · Görüntüleme: 104
    26,2 KB · Görüntüleme: 100
    29,5 KB · Görüntüleme: 80
    25,3 KB · Görüntüleme: 99
