Xpress recovery 2
Initial access by booting from CD-ROM and subsequent access by pressing the F9 key: Steps: After entering BIOS Setup, go to Advanced BIOS Feature and set to boot from CD-ROM. Save the settings and exit the BIOS Setup. Insert the provided driver CD into your CD-ROM drive. Upon system restart, the message which says "Boot from CD/DVD:" will appear in the bottom left corner of the screen. Press any key to enter Xpress Recovery2. After the steps above are completed, subsequent access to Xpress Recovery2 can be made by simply pressing the key during system power-on.
*NOTE:
1. For the first time of use Xpress Recovery2, user have to assign BIOS Boot up option to "Boot from CD-ROM", and put Driver CD into assigned optical drive. After reboot the system, when user's screen appears "Press any key to startup Xpress Recovery2", then press any key to run the Xpress Recovery2 program.
2. If user had experienced and installed Xpress Recovery2 application in PC before, user can run the Xpress Recovery2 application by press "F9" during boot up sequence.
3. If you have already entered Xpress Recovery2 by booting from the CD-ROM, you can enter Xpress Recovery2 by pressing the key in the future.
4. System storage capacity and the reading/writing speed of the hard disk will affect the data backup speed.
5. It is recommended that Xpress Recovery2 be immediately installed once you complete installations of OS and all required drivers as well as software.
The Main Screen of Xpress Recovery2
1. RESTORE: Restore the backed-up data to your hard disk. (This button will not appear if there is no backup file.)
2. BACKUP: Back up data from hard disk.
3.
4. REMOVE: Remove previously-created backup files to release disk space.
5.
6. REBOOT: Exit the main screen and restart the system.
Limitations:
1. Not compatible to Xpress Recovery.
2. For the use of Xpress Recovery2, a primary partition must be reserved.
3. Xpress Recovery2 will store the backup image file at the end of the hard disk,so user must reserve enough unallocated hard drive partition space in advance. (A minimum 4GB is recommended but the actual space is dependent on the size of the data to be backed up)
4. Capable of backing up hard disks installed with Windows operating systems including DOS and Windows Vista/XP/2K/NT/98/Me.
5. USB hard disks are currently not supported.
6. Does not support RAID/AHCI (class code 0104/0106) hard disks.
7. Capable of backing up and restoring only the first physical hard disk.
Hard disks detection sequence is as follows:
1. PATA IDE primary channel
2. PATA IDE secondary channel
3. SATA IDE channel 1
4. SATA IDE channel 2
5. SATA IDE channel 3
6. SATA IDE channel 4
Precautions:
1. It is normal that data backup takes longer time than data restoration.
2. Xpress Recovery2 is compliant with the GPL regulations.
3. On a few motherboards based on Nvidia chipsets, BIOS update is required for Xpress Recovery2 to correctly identify RAID and SATA IDE mode. Please contact your motherboard manufacturer.
4. Xpress Recovery2 supports only PATA hard disks and not SATA hard disks on the following motherboards:
GA-K8U
GA-K8U-9
GA-K8NXP-SLI
GA-K8N Ultra-SLI
GA-K8N Pro-SLI
GA-K8NXP-9
GA-K8N Ultra-9
GA-K8NF-9 (PCB Ver. 1.0)
GA-K8NE (PCB Ver. 1.0)
GA-K8NMF-9
GA-8N-SLI Royal
GA-8N-SLI Pro
GA-8N-SLI
It is highly recommended to always use the most recent driver version available.
Do not forget to check with our site as often as possible in order to stay updated on the latest drivers, software and games.
Try to set a system restore point before installing a device driver. This will help if you installed a wrong driver. Problems can arise when your hardware device is too old or not supported any longer.
Önyükleme CD-ROM ve F9 tuşuna basarak sonraki erişim tarafından ilk erişim: Adımlar: BIOS girdikten sonra Gelişmiş BIOS gidip CD'den önyükleme yapmak için set-ROM. Ayarları kaydedin ve BIOS çıkın. CD-ROM sürücüsüne verilen sürücü CD'sini yerleştirin. Üzerine sisteminizi yeniden başlatın, mesajı olan "Boot CD / DVD 'diyor:" alt ekranın sol köşesinde görünür. Herhangi bir tuşa basın Xpress Recovery2 girin. Sonra yukarıdaki adımlar tamamlandığında, Xpress Recovery2 sonraki erişim sadece sistem güç sırasında tuşuna basarak-on yapılabilir.
* NOT:
1. Kullanımı ilk kez Xpress Recovery2, kullanıcı için seçeneği CD "Boot-ROM BIOS Boot atamak" ve Sürücü koymak atanan optik sürücüye CD. Ne zaman kullanıcı ekran "Basın Xpress Recovery2", daha sonra herhangi bir Xpress Recovery2 programı çalıştırmak için anahtar başlangıç için herhangi bir tuşa basın görünür yeniden sistemi, sonra.
2. Eğer kullanıcı deneyimli vardı ve PC daha önce Xpress Recovery2 Uygulama yüklendiğinde, kullanıcı basın tarafından sıra çizme yukarıya sırasında "F9" Xpress Recovery2 uygulamayı çalıştırabilirsiniz.
3. Zaten CD'den açıp Xpress Recovery2 girdikten-ROM, size gelecekte tuşuna basarak Xpress Recovery2 girebilirsiniz.
4. Sistem depolama kapasitesi ve okuma / veri yedekleme hızını etkiler sabit disk hızı yazma.
5. Bu Xpress Recovery2 hemen bir kez ve gerekli tüm sürücüleri ve yazılım OS tesisatları yüklü olması önerilir.
Ana Ekran Xpress Recovery2 ve
1. RESTORE: Geri Yükleme destekli veri sabit diskinize kadar. Yoksa yedek dosyası (Bu düğme görünmez.)
2. YEDEK: Arka sabit diskteki verileri yedekleyin.
3.
4. KALDIR: Daha önce disk alanı serbest bırakmak için yedek dosyaları hazırlandı kaldırın.
5.
6. REBOOT: Çıkış ana ekran ve sistemi yeniden başlatın.
Sınırlamalar:
1. Değil Xpress Recovery uyumlu.
2. Xpress Recovery2, bir birincil bölümünün kullanımı için ayrılmalıdır.
3. Xpress Recovery2 sabit diskin sonunda, böylece kullanıcı yeterince önceden sabit disk bölüm ayrılmamış alanı rezerv gerekir yedek görüntü dosyası saklar. (En az 4GB ama gerçek alan veri boyutuna bağlıdır önerilir) yedeği alınacak
4. Sabit diskler DOS ve Windows Vista/XP/2K/NT/98/Me dahil olmak üzere Windows işletim sistemi yüklü yedekleme sığası.
5. USB sabit diskler şu anda desteklenmiyor.
6. RAID desteği Doesn't / AHCI (sınıf kodu 0104/0106) sabit diskler.
7. Yedekleme ve sadece birinci disk geri sığası.
Sabit diskler algılama sırası aşağıdaki gibidir:
1. PATA IDE birincil kanal
2. PATA IDE İkinci kanal
3. SATA IDE kanalı 1
4. SATA IDE kanalı 2
5. SATA IDE kanalı 3
6. SATA IDE kanalı 4
Önlemler:
1. Bu veri yedekleme veri restorasyon daha uzun zaman alır normaldir.
2. Xpress Recovery2 GPL düzenlemeler ile uyumludur.
3. Birkaç anakart Nvidia yonga dayalı, BIOS güncelleme Xpress Recovery2 doğru RAID ve SATA IDE modu belirlemek için gereklidir. Lütfen anakart üreticisine başvurun.
4. Xpress Recovery2 sadece PATA sabit diskleri değil, aşağıdaki anakartlarda SATA sabit diskleri destekler:
GA-K8U
GA-K8U-9
GA-K8NXP-SLI
GA-K8N Ultra-SLI
GA-K8N Pro-SLI
GA-K8NXP-9
GA-K8N Ultra-9
GA-K8NF-9 (PCB Ver. 1,0)
GA-K8NE (PCB Ver. 1,0)
GA-K8NMF-9
GA-8N-SLI Royal
GA-8N-SLI Pro
GA-8N-SLI
Oldukça her zaman en son sürücü sürümü kullanmanız önerilir.
Sıklıkta amacıyla son sürücüleri, yazılım ve oyun Güncelleme kalmak mümkün olduğunca site ile kontrol etmeyi unutmayın.
Bir sistem bir aygıt sürücüsü yüklemeden önce geri yükleme noktası eklemeyi deneyin. Eğer yanlış bir sürücü yüklediyseniz bu yardımcı olacaktır. Sorunları donanım aygıtı çok ya da değil artık desteklenen eski ortaya çıkabilir.
KAYNAK: Google Translate
