Some of the changes in XF 2.3.4 include:
The following are minimum requirements:
- Include embed.php in hashes.json
- Fix error thrown when feed entry is missing an ID
- Use AbstractCollection for type hint on addContentToBookmarks method
- Fix deprecated usage of str_replace with API scopes
- Improve PHP 8.4 compatibility
- Output hsla in the color picker when an alpha channel is present
- Ensure URLs are valid when analyzing image usage
- Coerce nestable group to a number before peforming strict comparison
- Gracefully handle guest username and style variation containing invalid UTF-8
- Attempt to work-around abysmal Firefox form field retention heuristics
- Gracefully handle when an avatar cannot be processed
- Allow changing style variation when the previously selected style is forced to the default style
- Increase date input width further to accomodate Firefox icon clipping
- Fix editor autofocus behavior when in BBCode mode
- Add a note about some permissions not being applicable to guests
- Fix triggering Facebook embeds for document
- Fix calculation of local load time from navigation timing API
- Fix behavior of preview buttons
- Consider read-only number-box inputs as disabled
- Make required and recommended function checks more robust
- Allow null unique ID when enqueuing a job later
- Make report creation notifications easier to extend
- Attempt to work around aggressive Firefox auto-complete heuristics when editing a user
- Fix broken JS handlers when loading comments via AJAX
- Fix an issue with editing newly translated phrases
- Split ExifReader library out of attachment manager bundle
- Attempt to work around aggressive Firefox auto-complete heuristics on control panel index
- Fix number input buttons when step is set to any
- Fix some icon usage analysis issues when editing and deleting editor drop-downs and BBCodes
- Only record icon usage for active BBCodes and editor dropdowns
- Omit itemid microdata attribute when there is no valid user
- Ensure all control panel functionality is covered by permissions
- Handle invalid multiquote input more gracefully
- Attempt to avoid featured content carousel pager text overlap
- Only try to remove double quotes from URL strings once
- Set default color picker color to white instead of transparent
- Fix some issues with the JS icon renderer and BBCode previews
- Handle invalid session IDs more gracefully
- Do not mark unhidden usernames as aria-hidden
- Fix direction of back arrow on RTL languages
- Improve text node handling in XF.setupHtmlInsert
- Ignore Thumbs.db in style archive validator
- Fix structured list icon end cell padding
- Fix an issue with deferred resize event listener after autofocus
- Skip any file duplicates when importing banned emails
- Mark multiple consecutive asterisks as an invalid term word on MySQL full-text searches
- Make the default table collation configurable
- Fix calculation of report closure notifiable users
- Ensure PayPal products are created with a unique ID.
- PAGE_CONTAINER
- approval_queue_macros
- carousel.less
- core_input.less
- fancybox.less
- helper_attach_upload
- lightbox.less
- message_macros
- profile_post_macros
- structured_list.less
Current requirements
Please note that XenForo 2.3 has higher system requirements than earlier versions.The following are minimum requirements:
- PHP 7.2 or newer (PHP 8.3 recommended)
- MySQL 5.7 and newer (Also compatible with MariaDB/Percona etc.)
- All of the official add-ons require XenForo 2.3.
- Enhanced Search requires at least Elasticsearch 7.2.
