XenForo XenAtendo (Events) 1.4.0
This mod adds an Event Schedule and RSVP system to XenForo... With this, administrators can define a forum as the "event forum". Then whenever a user submits an event, it will automatically create a thread in that forum, and tie the event into that thread. From there, users can RSVP for the event, as well as find additional information such as google map integration and live streams. This mod will also add an "Upcoming events for this week" module to the top of the defined event forum.
Features:
Event scheduling with auto-thread generation
RSVP system for registered users
Google Map integration for events
uStream/justinTV integration for event streams
Installation:
upload the entire contents of the attached zip to your XenForo root
install from file on server: "library/EWRatendo/addon_EWRatendo.xml"
set options for the event system in administration control panel
set usergroup permissions for administration rights
Usage Notes:
While the Event and it's Thread are linked, they are still separate entities. If an event is deleted, the linked thread will automatically be closed with a notice. However, if a thread is deleted, the link event will remain open in the system and will have to be deleted manually.
Screenshots:
[8wayRun.Com] XenAtendo (Events) v1.3.6 CHANGELOG
  • iFrame support has been added for stream chats that require it (justin, ustream and own3d).
  • Streaming support for the new service "Own3D.TV" has been added!
  • Calendar block on the portal now uses the OverlayTrigger for event dates.
  • Administrating services pages now have a "Save & Reload" function.
  • BUG FIX: Event Forum server error for guest users has been fixed.
[8wayRun.Com] XenAtendo (Events) v1.3.7 CHANGELOG
  • You can now enable and disable the ability for users to RSVP for an event.
  • There is a new option in the admin cp called "Archive Recurring Events with Disabled RSVP Systems". If disabled, past instances of recurring events with disabled rsvp systems will NOT be stored in the archive. Disabling this may clean up the clutter on your calendar and event archive.
  • Event Description for events without a thread will now automatically link as bbcode.
[8wayRun.Com] XenAtendo (Events) v1.3.8 CHANGELOG
  • This is a patch level change. It fixes some basic errors in the recurrence system introduced in 1.3.7. Please update.
[8wayRun.Com] XenAtendo (Events) v1.3.9 CHANGELOG
  • Added error support for streaming service hosters.
  • Fixed a bug where users who don't have permissions would see the create even button.
[8wayRun.Com] XenAtendo (Events) v1.4.0 CHANGELOG
  • Fixed a very big bug that was breaking the event recurrence cron job.
  • If you have archive recurring events disabled, events will retain their event id.
  • Recurring events with event threads will now automatically update thread titles.
  • Fixed some phrasing issues... I accidentally linked phrases to the wrong mod.
  • XenAtendo (Events) v1.4.0.zip
    92,1 KB · Görüntüleme: 2
    91,4 KB · Görüntüleme: 7
    90,7 KB · Görüntüleme: 5
    87,4 KB · Görüntüleme: 5
    89 KB · Görüntüleme: 4
    88,2 KB · Görüntüleme: 5
    80,3 KB · Görüntüleme: 4
    93,8 KB · Görüntüleme: 4
    86 KB · Görüntüleme: 4
    84,2 KB · Görüntüleme: 3
