xenforo similar threads (benzer konu eklentisi)
Question and Answers:
Q: Will Enhanced Search be used automatically if available?
A: Yes.
Q: Is it worth installing Enhanced Search?
A: Yes. Enhanced Search returns more accurate similar thread results.
Q: Do I ever have to rebuild the search or thread indexes to use this add-on?
A: No.
Q: Does Enhanced Search exclude common words?
A: Yes. XenForo will index your thread titles with common words removed.
Q: Are thread titles and posts searched?
A: Only thread titles are searched.
Q: Is the "View threads by others" set to Revoke honored?
A: Only if Same Forum is selected in Options.
How the standard search works:
Normally you will want to set "Allow" for the following two user groups:
Unregistered / Unconfirmed
Registered
A: Yes.
A: No.
- Get new thread title
- Remove common words
- Remove words less than five characters
- Remove punctuation
- From remaining words select first two words and see if other threads contain these keywords
- Both words
- first word
- second word
- Download similarthreads_v4.0.zip and unzip it.
- Upload the Andy folder to your server. The correct location is library/Andy.
- From your Admin Control Panel, go to the "Install Add-on" page.
- Upload the addon-SimilarThreads_v4.0.xml file.
- Click the Install Add-on button.
Registered
