XenForo 1.5.7 - Nulled
          _______  _        _              _    _______  _______  _______ _________ _______ _________
|\     /|(  ___  )( \      ( \   |\     /|( )  (  ____ \(  ____ \(  ____ )\__   __/(  ____ )\__   __/
| (___) || |   | || |      | |    \ (_) / | |  | (_____ | |      | (____)|   | |   | (____)|   | |
|  ___  || |   | || |      | |     \   /  | |  (_____  )| |      |     __)   | |   |  _____)   | |
| (   ) || |   | || |      | |      ) (   (_)        ) || |      | (\ (      | |   | (         | |
| )   ( || (___) || (____/\| (____/\| |    _   /\____) || (____/\| ) \ \_____) (___| )         | |
|/     \|(_______)(_______/(_______/\_/   (_)  \_______)(_______/|/   \__/\_______/|/          )_(
                      !!!Null with LOVE by HollyScript!!!
[ScRiPt iNfO]ƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒ
˛ Script name   : XENFORO 1.5.7 FULL
˛ Supplied by   : HOLLY
˛ Nullified by  : HOLLY
˛ Protection    : Removed
˛ Homepage      : http://xenforo.com
˛ Release date  : April-5-2016
˛ Release genre : XenForo
˛ Release type  : PHP/MySQL
˛ Price         : Forget it ;)
˛ NFO date      : April-5-2016
[DeScRiPtIoN]ƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒ
XenForo is  a commercial  Internet  forum software  written in the PHP
programming  language  using the  Zend Framework (A Rapid  Application
Development  Framework).  The software is  developed by  a team led by
former vBulletin  lead  developers  Kier  Darby  and  Mike  Sullivan .
[/End DeScRiPtIoN]ƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒ
[iNfO aBouT rElEaSe]
This release only safety if you download it from HollyScript.NL. We do
not include anythings can make harm your site.
We do not provide it to anyone or any sites. So if you read this file
when download files from other sites, you should carefully with it.
This release is shared by HollyScript.NL
[/End iNfO aBouT rElEaSe]
[iNfO aBouT gRoUp]ƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒ
E-mail: hollyscriptnl@gmail.com
If you like this script, just buy it.
[/End iNfO aBouT gRoUp]ƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒ
[/End ScRiPt iNfO]ƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒƒ
Today, we are pleased to release XenForo 1.5.7. This release fixes a number of bugs and issues that were found since the release of 1.5.6. As this is a maintenance release, the vast majority of the focus was an increase in stability.
Please note that we are now formally recommending that you upgrade to PHP 5.4 or newer. Our intention with XenForo 2.0 is to require PHP 5.4 or newer. If you are running PHP 5.3 or 5.2, you will receive a warning when installing or upgrading XenForo.
Some of the bugs fixed in 1.5.7 include:
  • The interface used by admins to update user passwords has been improved to prevent accidental changes due to autofill.
  • Improved usage of cURL in the PayPal upgrade processor to ensure that requests are still successful before the TLS 1.2 transition is required.
  • Remove template editor border radius due to Chrome bug with horizontal scrolling.
  • Add autofocus to the full page login form.
  • Prevent image BB codes from being rendered when they couldn't possibly work.
  • Fix issues with the BB code <-> HTML conversion process involving lists within alignment tags.
  • Improved indication when your search failed or did not run as expected due to containing censored words.
  • Allow case insensitive highlighting of non-Latin characters in search results.
  • Limit nesting in the HTML to BB code conversion to prevent stack overflow errors.
  • Fix various issues with thread tag importing.
  • Fix for template modification disabling not working correctly when imported via style XML.
See the Resolved Bug Reports forum for further information.
The following templates have had changes:
  • error_with_login
  • helper_login_form
  • login
  • message.css
Where necessary, the merge system within the "Outdated Templates" page should be used to integrate these changes.
