Installation
- Make sure you're running WordPress version 2.3 or better. It won't work with older versions.
- Download the zip file and extract the contents.
- Upload the 'wp-cumulus' folder to your plugins directory (wp-content/plugins/).
- Activate the plugin through the 'plugins' page in WP.
- See 'Options->WP Cumulus' to adjust things like display size, etc...
- Create a page or post and type [wp-cumulus] anywhere in the content. This 'tag' will be replaced by the flash movie when viewing the page. See here for more info.
- Add the following code anywhere in your theme to display the cloud. <?php wp_cumulus_insert(); ?> This can be used to add WP Cumulus to your sidebar, although it may not actually be wide enough in many cases to keep the tags readable.
- The plugin adds a widget, so you can place it on your sidebar through 'Appearance'->'Widgets'. Open the widget to access it's own set of settings (background color, size, etc).
