VSa - ChatBox (AJAX) 3.1.8
uydudoktoru
Yönetici
Yönetici
Info:
Powerful AJAX-based ChatBox for vBulletin.
Main Features:
-One step installation (no file uploads, no manual template modifications required)
-Put ChatBox on any forum page by setting script name and adding variable to desired template
-"ChatBox Full" (always available on separate page)
-"Messages Archive" (available on separate page, with options to edit/delete messages)
-"ChatBox Search"
-Option to block usergroups from viewing ChatBox
-Option to delete messages older than x hours automatically
-"ChatBox Statistics" (new messages since last visit, messages in last x hours, total messages, top x chatters,...)
-View users active in ChatBox (available in CBFull and Archive)
-Text formatting options (color, weight, style, decoration,...)
-Advanced Smiliebox
-Smiliebox options: total smilies available, smilies per row, smilie clipping, disable smilies...
-A lot of customizable stuff, including: set new/old status icons, time/date format, box height, message order, auto-refresh intervals,...
-One-click actions: View all messages posted by user X, Delete all messages posted by user x, Ban/unban user from ChatBox, View last message posted by user X, View your last message, View first unread message
-"/me" action (used when you want to refer to yourself in the "third person")
...and more...
View screenshots for more details.
Installation:
-Import XML file (as product): AdminCP > Plugin System > Manage Products > [Add/Import Product]
To add to desired template (example FORUMHOME):
1. Add 'index' to THIS_SCRIPT locations (Product options)
2. Add 'FORUMHOME' to template names (Product options)
3. Open 'FORUMHOME' template and put "{vb:raw vsachatbox}" to desired line (for example after '<!-- /main -->') -> Save
To set options:
Go to: AdminCP > vBulletin Options > VSa - ChatBox
Versions:
v1.0 - Sep 15. 2007.
-First version
v2.3 - Sep 22. 2008.
-Latest vB 3.x version
v3.0 - Feb 08. 2010.
-Rewritten for vB4
-Known bugs fixed, code optimized
v3.0.1 - Feb 09. 2010.
-Fixed: Wrong title alignment in box/archive tables
-Fixed: Wrong expand/collapse button alignment in Safari
-Fixed: Wrong 'Smilies' alignment
-Fixed: XHTML errors
-New Setting: List templates where "{vb:raw vsachatbox}" will be enabled
v3.0.2 - Feb 09. 2010.
-Fixed: PHP error on CMS on some configs
-Fixed: 'Smilies' alignment
-Fixed: Minor bugs in PHP/HTML
v3.1 - Feb 14. 2010.
-New: CB Log-in/Log-out
-New Option: Stop auto-refresh if user inactive for X minutes
-New Option: Disable custom colors completely
-New Option: Random smilies
-New Option: Align messages to the usernames
-New: Remove text formatting button
-New: 'Smilies' replaced by image, arrrow removed
-Fixed: Move focus to input field when smilie inserted
-Fixed: 'Expand' button not shown after refresh
-Fixed: Now first item in color list is used as default
-Settings reorganized
-Several style/functionality bugs fixed
v3.1.1 - Feb 14. 2010.
-Fixed: Small JS issue on log-out
-New Option: Logged-out by default
v3.1.2 - Feb 16. 2010.
-Fixed: Errors with PHP 5.3
-Fixed: CB table messed up in footer
-Fixed: Several style errors, including XHTML incompatibilities
-New: Auto-insert on forumhome location - Below Forums
-New: Option to reverse message order in CB Archive
v3.1.3 - Feb 19. 2010.
-Fixed: Color selector dimensions
-Fixed: Minor bugs
v3.1.4 - Feb 20. 2010.
-New: Color Select replaced by Color Menu (and it's sexy)
-Note: Above fixes issues with Safari for Mac
-Fixed: Issue with Default color if it's in RGB format
-Note: Above will not change already posted messages
-Fixed/improved: Several style details
-Note: You may die if your templates are not reverted after upgrade
v3.1.5 - Feb 20. 2010.
-Fixed: Chrome not showing Color menu
-Fixed: headinclude_bottom added to <head
v3.1.6 - Feb 24. 2010.
-Fixed: Several style/functionality issues
-New: Set groups NOT able to edit messages
v3.1.7 - Jan 21. 2012.
-Fixed: Status images
-Fixed: Smilies button
-Fixed: Menu items invisible until highlighted
-Fixed: Several style issues (background, menus, colors, smilies)
-Fixed: https links not parsed automatically
-New: Show ChatBox in selected forum only
-New option: Automatically disable auto-refresh if server load is higher than X
-New Option: Set usergroups able to prune ChatBox
-New: 'Prune ChatBox' option available in the Main ChatBox drop-down menu
-Improved: Product menus re-organized
-Minor bugs fixed, codes optimized
http://www.mediafire.com/download/6j7rttt5vk6s8zd/VSa+-+ChatBox+v3.1.8.zip
link bozuk
Info:
Main Features:
-"ChatBox Search"
-Advanced Smiliebox
...and more...
Installation:
To set options:
Versions:
-First version
-Rewritten for vB4
-Fixed: Minor bugs
link kırık
