Varicaps and varactor diodes Hakkında Bilgiler
1SV217 Very wide range: 39 pF @ 2V (approx. 50pF @ 0.5V),pF @24V SOD323 (little
smd block)
1SV149 = BB112 =20 à 500pF 1 à 8V
BA102 Special varicap diode for transmitters
BA112 BB809 15---60pF 20v
BB105 =205 UHF stripline
BB112 = KV1235 =MVAM115 1SV149(1à8V 20-500pF) 30----450pF 12v inverse maxi
varicap TO92 2-pin see KV1235
BB119 AFC varicap axiaal
BB130 560pF varicap, see KV1225
BB204 =104=304 VHF 2x40pF TO92
BB204B same 1.13
BB209 =109 VHF 40pF stripline
BB212 use 2 x BB112 or 2 x KV1235
BB215 =205 in SMD SOD80 (round, MELF)
BB221 =521AX UHF/SHF high-Q axial
BB313 3 x 500 pF SIL6
BB329 2---38pF 30vVHF axial
BB405 = 2---11pF 30v = 505 UHF axial
BB409 VHF/CATV varicap 45 pF axial
BB509 see BB112 or KV1235
BB510 SMD sot23 500pF varicap 1-8V
BB515 improved BB215 smd SOD123 (little block) 2-10pF
BB521AX see BB221
BB521-SOT23 smd varicap 1.8pF miniature
BB529 VHF AFC axial
BB531 VHF super range 2-40 pF axial
BB609 35pF axial
BB619 3-45 pF SMD see BB629
BB621 see BB521-SOT23
BB629 Wide range 2.5-38 pF smd
BB640 Siemens SHF varicap
BB701 0.8-8pF high-Q SMD little block- very low noise
BB801 same SOT23 SMD
BB809 Axial widerange 4.5-43 pF
BB811 UHF/SHF SMD Dubus SOD123 (little block) SOD123 1-9 pF
BB813 TV/SAT as BB811 but wider range: 0.6-12 pF SOD123
BB833 TV/SAT as BB813, even smaller: SOD323
BB835 TV/SAT/SHF SOD323 0.5-9 pF
BB814 2x40pF in SMD
BB909 2.8-35 pF varicap axial
BB910 axial, large range: 2.6-40 pF
BB911 same, 2-55 pF
BBY31 SMD UHF 10pF hi-Q prof.
BBY40 40pF in SMD prof.
DH71010-51 0.7 - 2 pF 0.5-24V Q=4300 @ 50 MHz SOT23 Fmax= 4 GHz
DH71010-53 same dual
DH71020-51 1.2 - 4 pF 0.5-24V Q=3900 @ 50 MHz SOT23 Fmax= 4 GHz
DH71020-53 same dual
DH71045-51 3.0 - 10pF 0.5-24V Q=3000 @ 50 MHz SOT23 Fmax= 3 GHz
KV1235 560pF 9V high-Q (=KV 1215 etc.) = MV1401 = 1 V/500pF, 8 V/25 pF
KV1225 550pF 25V high-Q =KV1226 per diode:
KV1310 40pF high-Q TO92 = BB304
KV1330 2x40pF 3-pin high Q
MA4ST401 Varactor diode MA/COM smd 1-10 pF Q=250
MV209 6-30pF TO92 Motorola high-Q (ex-equipment)
MV1401 Motorola super-Q 30-600pF 1-10V Q=200 axial see KV1235
MV2105 voir MV2109 6.86-100pF 30V
MV2109 voir MV2105
SMV1233 Alpha SOT23 single 1,5pF @ 1V - 0,4pF @ 6V - 15V max.
Seite
  • varicaps.pdf
    11,5 KB · Görüntüleme: 7
Varikap diyotlar : voltaj uygulanarak kondansatör değeri değiştirilen diyotlar olup OSC devrelerinden tunerler vericiler alıcılar gibi yerlerde genellikle kullanılırlar.
