UNV EZTools Programı EZTools 2.0-EZTools-B1122.2.2.0
Features:
EZTools 2.0 is a tool kit for device management, channel management, device upgrade and maintenance, recording time and capacity calculation.
● Device Management: Search device; Change device password and IP; Configure device remotely including device name, time and network.
● Channel Management: Configure the image, encoding, OSD, and audio (for IPC only) settings.
● Batch upgrade: Upgrade devices using an upgrade file on the PC; Upgrade devices with Internet connection.
● Device Maintenance:Restore device to default settings; Import and export device configuration; export diagnosis info; Restart device.
● NVR Channel Management: Add or delete NVR channels.
● Capacity calculation: Calculate the allowed recording time based on the given disk space; Calculate the required disk space based on the given recording time.
System Requirements:
ItemRequirements
Operating SystemMicrosoft Windows 7/ Windows 8/ Windows 10(32-bit or 64-bit).
CPUIntel Pentium IV 3.0 GHz or higher.
Memory1 GB or higher.
Display Definition1280*720 or higher.
Update Log:
1. Allows non-admin user to run the software.
2. Can display password in plain text during login and when changing password.
3. Fixed the problem that EZTools and Windows taskbar will block each other at low resolution.
4. Bug fixes.
