A truly minimalist circuit. Performance is relatively poor and stability is a problem. Q1 modulates the signal and acts as an oscillator. L1 and C5 determine the frequency. Decrease C5 for a higher frequency and vice-versa.
You won’t get a long range transmission with this one. The author claims 50-500 feet. A lot depends on the antenna. It must be made of stiff wire or else the frequency will change as you move the antenna. Experiment with different lengths to get the maximum range. 50cm or less should work reliably most of the time. A longer antenna might give even better range but if you exaggerate, the circuit will begin to oscillate and performance will drop dramatically. A regular telescope whip should work, too.
Malzeme Listesi
R1 27k
R2 56k
R3 12k
R4 100
C1 1u
C2, C3 470p
C4 6 to 10p
C5 1-30p trimmer
L1 etched on PCB or a center-tapped coil 5mm in diameter, 6-8 turns of enamel-coated wire 1mm thick
Mic Electret microphone
Q1 2N3564, 2N5225 (other general-purpose NPN transistors will work, too)
Tek transistör ile yapılmış güzel ve basit bir fm verici devresi
Yazar: guclusat
Makale başlığı: Tek Transistörlü FM TRANSMITTER (2N3564,2N5225)
