TDA1514A 2X50W Anfi Devresi
TDA1514A tek başına 50 watt güç verebiliyor besleme voltajı maksimum + – 30 volt mute/stantby sıcaklık koruması aşırı akım koruması bulunuyor. Bir kaç pasif eleman ile anfi devresini yapabilirsiniz
The TDA1514A integrated circuit is a hi-fi power amplifier for use as a building block in radio, tv and other audio applications. The high performance of the IC meets the requirements of digital sources (e.g. Compact Disc equipment). The circuit is totally protected, the two output transistors both having thermal and SOAR protection The circuit also has a mute function that can be arranged for a period after power-on with a delay time fixed by external components.
· High output power
· Low harmonic distortion
· Low intermodulation distortion
· Low offset voltage
· Good ripple rejection
· Mute/stand-by facilities
· Thermal protection
· Protected against electrostatic discharge
· No switch-on or switch-off clicks
· Very low thermal resistance
· Safe Operating Area (SOAR) protection.
