This is a circuit of a very simple 2 x 40 Watt audio amplifier using TDA8560q IC. TDA8560q is a 13 lead SIL package IC. It contains many build in features like very less external components due to which the circuit become simple and can be fixed in a small place but provide high output power like 2 x 25W in 4 ohms load and 2x 40W in 2 ohms load. The other features are short circuit protection, high temperature protection etc.
The IC / circuit can be operated with 6V to 18V DC due to which it is ideal to use as a car audio amplifier or portable audio amplifier at any place.
Çok kolay çok ucuz bir amplifikatör her hangi bir sorun idrak etmiyor ben 70 watt lık iki tane kolon bağlamıştım bu devreye 70 watt mono anfi eklerseniz 2+1 olarakda kullanılması etkili oluyor
