This is the Super Bright LED night lamp circuit diagram and it operates by using 230v mains current. We used 30 white LEDs for D5 to D34 and it gives good super bright. You can use this night lamp as a multipurpose lamp in Sitting room, Bedroom and other places. The circuit uses 60mA current and this night lamp good solution against to the higher power consumption lamps. You can build this circuit using a very little space. Try to invent architectonic LED night lamp using this circuit.
Components:
R1 – 180K
R2 – 4.7
C1 – 1.5uf/400V (155) Polyester
C2 – 470uf
D1-D4 – 1N4007
D5-D34 – 30 White LEDs
Components:
R1 – 180K
R2 – 4.7
C2 – 470uf
D1-D4 – 1N4007
