Stereo 80Watt Audio Power Amplifier TDA7294. The described circuit uses two TDA7294 for use in stereo (2 x 80 watts) and bridge mode (1x 180 watts), configure this setting only four drivers.
To facilitate the installation of each fuel. The performance is a kind of symmetry with a simple bridge rectifier 6A, and two large electrolytic capacitors, which 10000μF 22000μF/50v. This power supply circuitfor two modules. The processor is recommended 22-0-22 to 28-0-28 / 5 A, depending on the quality of the transformer is at least 6 amps is recommended.
The TDA7294 is a monolithic integrated circuit in MULTIWATT15 package for use as audio class AB amplifier in Hi-Fi field applications (stereo, powered speakers, car, high-end TV) is provided. Many thanks to the wide range of voltage and current capacity he is able to offer the highest property taxes in both 4Ω and 8Ω, to offer even in the presence of poor supply regulation, with the rejection of high-voltage power supply
