STA 540 Devre şeması
STA540 / TDA7375 DIY Guide - 38W / 35W Stereo Bridge / 13W Quad Single Chip Power Amplifiers​
STA540 application​
Quick facts STA540​
  • Power output: 2x 34W into 8 ohms at 10% 1kHz distortion with power supply 22V
  • Power output: 2x 38W into 4 ohms at 10% 1kHz distortion with power supply 18V
  • Power output: 4x 7W into 8 ohms at 10% 1kHz distortion with power supply 22V
  • Power output: 4x 11W into 4 ohms at 10% 1kHz distortion with power supply 18V
  • Power output: 2x 18W into 8 ohms at 1% 1kHz distortion with power supply 18V
  • Power output: 2x 8W into 8 ohms at 1% 1kHz distortion with power supply 12V
  • Gain: 26dB fixed in bridge mode, 20dB fixed in single ended mode
  • Power supply: 8V to 22V single supply
  • Class AB
Stereo plus bridge drive / 2.1 application​
Microprocessor control​
Note: I've not built and tested these chips on a microprocessor, therefore the above schematic is not verified, but should be fine. Contact me if you've verified it yourself.
