Solid State Relay Switch is a simple project which will help you control (ON / OFF) a single high power circuit from a low power drive.
Katı Hal Röle Anahtarı, düşük güçlü bir sürücüden tek bir yüksek güç devresini kontrol etmenize (AÇIK / KAPALI) yardımcı olacak basit bir projedir.
- Load – 24 to 240 VAC @ 500 W
- Trigger voltage – 2 to 5 VDC (TTL) @ 10 mA
- Input isolated with use of Optocoupler
- Power Battery Terminal (PBT) for easy input 230 VAC mains and load connection
- Terminal pins for connecting input trigger signal
- Heatsink for TRIAC
- Four mounting holes of 3.2 mm each
- PCB dimensions 29 mm x 74 mm
