Software Version 0.98D5 ( PCB45C (0.98D5)
Software V 0.98D5 Support Hardware Willem EPROM Programmer PCB4.5C Only.
  • Add device ID,Menu,Table index :28F002/004/200/400BX-x (TSOP40A,TSOP48 8/16bit, PSOP44) Version 098D5
  • Fixed Program Config PIC16F8x, PIC16F62x, PIC16F87x
  • - Fixed ID PIC18F84A (Test on PIC16F84, PIC16F84A, PIC16F627/628/628A, PIC16F872/877)
  • Fixed Timming Programming PIC12C5xx (Run on Windows XP) Test on PIC12C509JW UV erase), PIC16C505JW (UV erase),PIC12F509 (select device = PIC12C509A)
  • Add PIC microchip 14bit PIC12F629/675 , PIC16F630/676 , PIC12F635/683 , PIC16F636/684/688 , PIC16F72/73/74/76/77 , PIC16F737/747/767/777 , PIC16F87/88 , rfPIC12F675x , PIC16F785/PS200 , PIC16F716
  • Add microchip 14bit OTP PIC12C671 , PIC12C672 , PIC12CE673 , PIC12CE674 , PIC16C61/71 , PIC16C62/64/65/73 , PIC16C62A/62B/62C/63/63A/64A/65A/65B/66/67 , PIC16C72/72A/73A/74A/74B/76/77 , PIC16C620/620A/621/621A/622/622A , PIC16CE/623/624/625 , PIC16C710/711/712/716 , PIC16C773/774 , PIC16C745/765/923/924 , PIC16C925/926 , PIC16C554/556/557/558 , PIC16C432/433 , PIC16C717/770/771/781/782
  • Add PIC microchip 12bit (FLASH memory) PIC12F508/509 , PIC10F200/202/204/206 , PIC16F505 , PIC16F54/57
  • Add PIC18Fxxx PIC18F242 , 18F248 , 18F252 , 18F258 , 18F442 , 18F448 , 16F452 , 16F458 PIC18F1220 , 18F2220 , 18F4220 , 18F1320 , 18F2320 , 18F4320 PIC18F6520 , 18F6620 , 18F6720 , 18F8520 , 18F8620 , 18F8720 PIC18F2331 , 18F2431 , 18F4331 , 18F4431
  • PIC18F6525 , 18F6621 , 18F8525 , 18F8621 PIC18F6585 , 18F6680 , 18F8585 , 18F8680
  • PIC18F2439 , 18F2539 , 18F4439 , 18F4539 PIC18F6410 , 18F8410 , 18F6490 , 18F8490
  • -Add PIC18Fxxx PIC18F2410 , PIC18F2420 , PIC18F2455
  • PIC18F2510 , PIC18F2515 , PIC18F2520 , PIC18F2525 , PIC18F2550 , PIC18F2585
  • PIC18F2610 , PIC18F2620 , PIC18F2680
  • PIC18F4410, PIC18F4420 , PIC18F4455
  • PIC18F4510 , PIC18F4515 , PIC18F4520 , PIC18F4525 , PIC18F4550 , PIC18F4585
  • PIC18F4610 , PIC18F4620 , PIC18F4680
  • Add Find and edit value OSCCAL (PIC12F629/675 , PIC16F630/676)
  • Add Edit config at address 0x2008,0x2009 (PIC12F635/683 , PIC16F636/684/688 , PIC16F785)
  • Fixed Programming PIC all Test on chip
  • PIC12F675 , PIC16F676 , PIC16F684 ,PIC16F767, PIC16F74
  • PIC16F872 , PIC16F876 , PIC16F877, PIC16F876A, PIC16F873A, PIC16F819
  • PIC16F84 , PIC16F84A , PIC16F628, PIC16F628A, eprom PIC12C509JW , PIC16C505JW , PIC16C711JW , PIC16CE625JW
  • PIC18F458 , PIC18F4320 , PIC18LF258 , PIC18F4539 , PIC18F4431
  • - Fixed Write/read/verify EEPROM 18F4550
  • - Fixed Bug program 18Fxxx run on Windows XP/2000 (test PIC18F4539 , PIC18F2680 , PIC18F2431 , PIC18F258 , PIC18F4220 , PIC18F4550)
  • Add find OSCCAL 10Fx00, 12F50x, 12F6xx (test PIC10F202, 12F509, 12F675) Version 0.98D2 ( PCB3B/PCB35 And PCB4C [0.98D2] ) (5/July/2005)
  • Fixed Write/read/verify EEPROM 18F4550
  • - Fixed Bug program 18Fxxx run on Windows XP/2000 (test PIC18F4539, PIC18F2680, PIC18F2431 PIC18F258, PIC18F4220, PIC18F4550)
  • Fixed Programm AT89C8253 (Want modify Adapter MCS-51) (test on AT89S8253); Version 0.98c ( PCB3B/PCB35 [0.98c] )
  • Add PIC microchip 14bit PIC12F629,PIC12F675, PIC16F630, PIC16F676 ,PIC12F635, PIC12F683, PIC16F636, PIC16F684, PIC16F688
  • PIC16F72/73/74/76/77, PIC16F737/747/767/777,PIC16F87/88, rfPIC12F675x, PIC16F785/PS200, PIC16F716
  • Add microchip 14bit,12bit OTP
  • PIC12C671,PIC12C672,PIC12CE673,PIC12CE674
  • PIC16C61/71,PIC16C62/64/65/73, PIC16C62A/62B/62C/63/63A/64A/65A/65B/66/67
  • PIC16C72/72A/73A/74A/74B/76/77, PIC16C620/620A/621/621A/622/622A
  • PIC16CE/623/624/625, PIC16C710/711/712/716, PIC16C773/774, PIC16C745/765/923/924,PIC16C925/926
  • PIC16C554/556/557/558, PIC16C432/433, PIC16C717/770/771/781/782
  • PIC12F508/509, PIC10F200/202/204/206,PIC16F505, PIC16F54/57
  • Add PIC18Fxxx
  • PIC18F242,18F248,18F252,18F258,18F442,18F448,16F452,16F458
  • PIC18F1220,18F2220,18F4220,18F1320,18F2320,18F4320
  • PIC18F6520,18F6620,18F6720,18F8520,18F8620,18F8720
  • PIC18F2331,18F2431,18F4331,18F4431
  • PIC18F6525,18F6621,18F8525,18F8621
  • PIC18F6585,18F6680,18F8585,18F8680
  • PIC18F2439,18F2539,18F4439,18F4539
  • PIC18F6410,18F8410,18F6490,18F8490
  • Add PIC18Fxxx
  • PIC18F2410, PIC18F2420, PIC18F2455
  • PIC18F2510, PIC18F2515, PIC18F2520, PIC18F2525, PIC18F2550, PIC18F2585
  • PIC18F2610, PIC18F2620, PIC18F2680
  • PIC18F4410, PIC18F4420, PIC18F4455
  • PIC18F4510, PIC18F4515, PIC18F4520, PIC18F4525, PIC18F4550, PIC18F4585
  • PIC18F4610, PIC18F4620, PIC18F4680
  • Add Find and edit value OSCCAL (PIC12F629/675, PIC16F630/676)
  • Add Edit config at address 0x2008,0x2009 (PIC12F635/683,PIC16F636/684/688,PIC16F785)
  • Test on chip
  • PIC12F675, PIC16F676, PIC16F684 ,PIC16F767, PIC16F74
  • PIC16F872, PIC16F876, PIC16F877, PIC16F876A, PIC16F873A, PIC16F819
  • PIC16F84, PIC16F84A, PIC16F628, PIC16F628A,
  • eprom PIC12C509JW, PIC16C505JW, PIC16C711JW, PIC16CE625JW
  • PIC18F458, PIC18F4320, PIC18LF258, PIC18F4539, PIC18F4431
