SMD Kod Okuma
SMD Kod Okuma
A - Transistör - Triak - Thyristör - Diyot
SMD devices are, by their very nature, too small to carry conventional semiconductor type numbers.
Instead, a somewhat arbitrary coding system has grown up, where
the device package carries a simple two- or three-character ID code.
Identifying the manufacturers' type number of an SMD device from
the package code can be a difficult task, involving combing through
many different databooks.
This HTML book is designed to provide an easy means of device
identification. It lists well over 3,400 device codes in alphabetical
order, together with type numbers, device characteristics or
equivalents and pinout information.
How to use the SMD Codebook
To identify a particular SMD device, first identify the package style and note the ID code printed on the device.
Now look up the code in the alphanumeric listing which forms the main part of this book by clicking on the first
character shown in the left-menu.
Unfortunately, each device code is not necessarily unique. For example a device coded 1A might be either a
BC846A or a FMMT3904. Even the same manufacturer may use the same code for different devices!
If there is more than one entry, use the package style to differentiate between devices with the same ID code.
This compilation has been collected from R P Blackwell G4PMK, manufacturers' data and other sources of SMD
device ID codes, pinout and leaded device equivalent information.
The entries under the Manufacturer column are not intended to be comprehensive; rather they are intended to
provide help on locating sources of more detailed information if you require it.
ID Code Variations
Many manufacturers use an extra letter as their own identification code. If the device is from Philips it will
sometimes have a lower case 'p' (or sometimes 't') added to the code; Siemens devices usually have a lower
case 's'.
For example, if the code is 1A, according to the table there are a number of possibilities:
· 1A BC846A Phi ITT N BC546A
· 1A FMMT3904 Zet N 2N3904
· 1A MMBT3904 Mot N 2N3904
· 1A IRLML2402 IR F n-ch mosfet 20V 0.9A
This has been a problem in the past, however recently manufacturers have been adding lower case letters
which clarify the code.
Many recent Motorola devices have a small superscript letter after the device code, such as SAC . (This smaller
letter is merely a month of manufacture code.)
Many devices from Rohm Semiconductors which start with G have direct equivalents found in the rest of the
number. For example GD1 is the same as D1 which is a BCW31.
Some devices have a single coloured letter (usually on extremely small diode packages). Colour, if significant, is
shown in small type after the code letter.
An 'L' suffix usually indicates a low-profile package, such as an SOT323 or SC70.
Reverse joggle devices do present a few problems. They oftern have an 'R' in the type number. A reverse
package is one where the lead have been bent up instead of down. So it's a mirror image of a conventional
device. Identification is usually possible from the code number, but some manufacturers use the same code. In
these cases, it's a case of looking at the device with a magnifying glass. The leads of most normal packages
come out closer to the circuit board side of the device; conversely a reverse joggle package will have them
coming out closer to the 'top' of the device.
Sometimes a series of devices, derived from the same die, have related type (not code) numbers. Often an 'R' will
indicate a reverse joggle package, and/or a 'W' indicate a smaller package variant, such as SOT343.
Sometimes similarities are also found in the code numbers. For example:
Recently some manufacturers have used a symbol or lower case letter to indicate the country of manufacture.
These have been ignored in the alphabetical ordering. For example:
· '67' is the code for a BFP67 (SOT143 package) ,
· '67R' is the code for the reverse joggle variant BFP67R (SOT143R),
· 'W67' is the code for a SOT343 package version.
'Z-S' and 'ZtS ' are both 2PC4081Q devices made by Philips; the first made in Hong Kong
and the second in Malaysia; this appears in the codebook classified under ZS.
Leaded equivalent device and information
Where possible, the listing gives the part number of a conventional wire-leaded device with equivalent
characteristics. If the leaded device is well-known then no more information is given. If the device is less common,
some additional information will sometimes be given. Where no exact leaded equivalent exists, a brief device
description is given, which may be sufficient to allow substitution with another device.
When describing device characteristics, some terms are implied from the type of device. For example, a voltage
specified for a rectifier diode is usually the maximum PIV (peak inverse voltage) of the diode, but for a zener
diode the operating (zener voltage) will be given.
Normally, where a voltage, current or power is specified, these will be limiting values. For example, a device
specified as NPN 20V 0.1A 1W is a NPN transistor with a Vce (max) of 20V, maximum collector current of 100mA
and a maximum total power dissipation of 1W. Some of the transistors are types with integrated resistors; in the
list, a base resistor means a resistor connected in series with the base. When two resistor values are given, the
first is the series base resistor, and the second the resistor between base and emitter.
Devamı ektedir.
