Single Transistor Audio Mixer Circuit
Tek transistör ses karıştırıcı devresi
Audio Mixer is an essential device in Audio Electronics. The mixer mixes two or more audio signals into a one (Mono) or two output (Stereo). The audio mixer uses audio mixing process where multiple sounds are combined to form a single or multi-sound. It is a widely used process in Live concerts, televisions, films, music industries etc.
In this project, we will make Audio mixer using a single transistor which will combine two or more audio signals and produce a combined audio output. In this circuit, two audio inputs will be mixed using a single transistor to produce a mixed audio output.
Required Components
  1. PN2222A transistor
  2. 2 or more 4.7k resistor (one for each input channel)
  3. 2 or more .1uF ceramic disc capacitor (one for each input channel)
  4. 470pF ceramic disc capacitor
  5. .22uF ceramic disc capacitor
  6. 3.9k resistor
  7. 2.2M resistor
  8. 12V clean DC power supply unit. (350mA rated can be used)
  9. 100uF / 16V Electrolytic capacitor
  10. Separate Audio signals for mixing.
Audio Mixer with 3-Channel Input
The circuit was designed to provide an overall gain of one between the output and each input channel on an audio mixer with 3-channel input.
A mixer is a device that can be used to merge two or more electronic signals into one complex output. It can have a classification as frequency mixer, electronic mixer, audio mixing console, mode mixer, or vision mixer.
A single capacitor with 0.1uF value is attached in every input channel along with a 100K Ohms resistor in order to provide 100K Ohms output impedance. Adding more capacitors and resistors with the same values of 0.1uF and 100K Ohms respectively, will increase the number of input channels to this audio mixer. The proper location of the mixer os situated between the input to the power amplifier and the output of the tone control circuit. The other inputs should either be grounded or taken from the desired source while one input should be taken from the output of the tone control circuit.
The transistor 2N3904 was designed for general purpose low power amplifier and switch applications which can extend to 100mA as a switch and to 100MHz as an amplifier.
