Setting up Samsung Smart TV/Blu-Ray Players
After extensive testing with Samsung smart TV's here in Canada and in the UK, it is the case that on some devices BBC iPlayer will not work. This is probably because Samsung locks down various apps by the TV model number, as model numbers in the UK are different to those in Canada and elsewhere.
Sadly there isn't very much we can do about this as it's a hardware limitation.
Please note that the VUDU app is not available to watch on any Samsung device sold out of the US. You can download it - but it will not workThis is due to a serial number block for this app. This is out of our control.
This guide will show you how to set up your Samsung TV/Blu-ray player to use our service. We'll also cover installing the UK apps (bbc iPlayer, ITV Player etc) & The US apps (Hulu Plus etc)
First you need to press Menu on your remote
110266
This will open the settings menu > scroll down to Network
110267
Next select Network Settings
110268
Your TV/Bluray player will now tell you how you have it connected to the internet. Press Start.
110269
If you have a wireless Network you'll have to select your network and input your passkey. If your connected via ethernet this will not appear.
110270
Your device will now test that it's connected to the internet. Next select IP Settings
110271
Scroll down to DNS settings and input our DNS address then press OK
110272
Your connection will test itself again. Press Next to save the settings and exit the menu.
110274
Smart Hub Steps
Next, press the smart button on your remote,
110279
When you see the Smart Hub (below) you need to press fast forward, 2, 8, 9, rewind keys on your TV remote (If you have a newer F series Samsung TV please use the new keypress as detailed here)
110280
110421
These are the buttons on your remote control
110284
The internet service location will appear. If you wish to download UK apps such as BBC iPlayer select United Kingdom. If you wish to view US apps (Vudu, Hulu plus etc) Select United States. Please Note you cannot select 2 regions, i.e you can't have access to Vudu (US) and BBC iPlayer (UK) at the same time. You must repeat the smart hub steps every time you want to change.
110308
As above we have selected UK. Select Next. You will need to agree to the terms of service.
110311
Once you have agreed to the terms, the smart hub will need to restart.
110312
When the Smart Hub has restarted it will now be set to your chosen region and download the default apps for your new region. If you have previous switched regions your old regions apps will be deleted before this happens (below).
110313
Your device will download the default apps for the new region. If it doesn't you can access them to download via the Samsung apps button.
110314
