Samsung TÜm Telefonlar İÇİn Kodlar
Belki bu kod bir çogunuzun işine yarar. *2767*2878# bu kodala güvenlik kodunu kaldıra bilirsiniz,telefonunuzda donma varsa kaldıra bilir,bazı larında ise simlock kıra bilirsiniz
samsung ---SGH-600:
*2767*3855#
S100, S300, V200:
*2767*7822573738#
A300, A800
*2767*637#
X100, S500 and E700 E710 T500
*2767*688#
Also for Samsung X-100!
*#7337#
Samsung SGH-E700 new model:
#*7337#
*2767*2878# Custom EEEPROM Reset
#*7337# IS WORKING ON X600,TESTED.
*0001*s*f*t# -> Changes ****** parameters (s=?, f=0,1, t=0,1) (incomplete)
*2767*3855# -> Full EEPROM Reset ( THIS CODE CAN REMOVE SP-LOCK ON SOME PHONES!! )
*2767*2878# -> Custom EEPROM Reset
C100
How unlock C100...I know!!! Really!!! code: *#9998*627837793# ...he says "wrong operation", but in Settings is new menu "file manager" ...go to File manager and step by step make all! Then restart, and all ok!
*#9998*627837793#
and another one code for display contrast for 2xx,nxxx
code;*#0523#
New Cod For New Version X100 X600 E700
#*7337#
Samsung X426: * 2 7 6 7 * 3 8 5 5 #
r220.
*0141#
Samsung SGH2100
*2767*3855#
*2767*2878#
SGH S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
SGH V200
Unlocking:
Power on the phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK!
but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
FOR NEW SGH (R210, T100, A300...)
if code is in format *#9998*xxx#
try write in this *#0xxx#
SAMSUNG UNLOKING CODE
#*7337# E700 E715 AND T200 T500 S105 S100 X100 X600
ENTER SIM
*#9998*3323#AND PRESS EXIT THEN PRESS No.7KEY PHONE WILL B RESTART
PHONE UNLOCKED?
E820 On TMobile
*2767*3855# [full]
v200 *2767*7822573738# tested.100% successful........
X450
d500 UNLOCKING FREE!!!!
switch phone on without sim and enter :-
#*7337#
Then phone will reset ... and it is unlocked....
D500 unlock code #*7337#
a300 i try
*2767*2878and *2767*688 without sucess
aynen simlock kırmak için ve guvenlik içindir...
Samsung D500 D600 D820 X700 kullanıcılarının işine yarayacak bazı kodlar...
Bu sayede yolculukta MP3 dinleyebilir, java uygulamalarınızı çalıştırabilir veya döküman okuyarak yolcuğunuzu daha da kısaltabilirsiniz...
otobüste veya bunun gibi cep telefonunuzun zarar vereceğini düşündüğünüz mekanlarda
artık telefonunuzu kapatmanız gerekmiyor.
Ne yapmalıyım diyorsanız;
1- Telefonunuzdaki sim kartı çıkartın ve telefonunuzu açın
2- Sim kartı takın mesajını aldığınızda şunu tuşlayın: #*5737425#
3- Ardından çıkan menuden 1 PPP UP OK,2 USB OK,2'yi yani "Seri yükleme" seçeneğini tuşlayın BU İŞLEMİ HIZLI YAPIN
ve Telefonuzu artık kullanabilirsiniz, hayırlı olsun.
Ses kayıt:
Cep telefonunuza #*22671# kodunu girin daha sonra görüşme yapın ve görüşmelerinizi kayıt etsin.Kapatmak için #*22672# tuşlayın kayıt biter kayıtlar sesler bölümüne kayıt olur ordan dinleyebirsiniz...
RADYODAN KAYIT:
ARKADAŞLAR X 700 VE E 250 RADYOSUNDAN TELE ÇEKİM YAPABİLİRSİNİZ NASILMI.RADYOYU AÇ SESİ HOPARLÖRE DIŞA VER SONRA GERİ ARAMA EKRANINA DÖN RADYO AÇIK KALSIN SONRA TELDEN *#22671# YAZIN EKRANA YAZI GELECEK O YAZIYI KAPATMAYIN ŞUANDA RADYODAN TELE ÇEKİM YAPIYOR.ÇEKİMİ SİZ DUYAMIYORSUNUZ AMA KAYIT YAPIYOR ÇEKİMİ KAPATMAK İÇİN *#22672#TUŞLAYIN BUKADAR KOLAY GELSİN
FORMAT KODU
reset kodu *2767*3855# telefon hafızası ve mesajlar, mms ve gprs ayarlarınız silinir java dünyası fotograflar videolara ve seslere birşey olmaz bu kodla
..::İstediğiniz Numaradan kendinize mesaj yollayin::..
1. *#8999*8378# sifresini telefonunuza girin
2. 6.Metin Mesaj seçin
3. 1.Mesaj Kaydet
4. Bütün ayarlari oldugu gibi birakiyorsunuz.
5. Telefon numarasi yazan yere istediginiz kişinin numarasını yazıyorsunuz.
6. Data Yazan yere istediginiz mesaji yaziyorsunuz
7. File seçiyoruz ve istediginiz yere kaydediyorsunuz (standart gelen kutusu)
8 1Menü-2mesajlar-3mesajlarim-4(gelen kutusu)
Teldeki "g" işaretini kaldırmak
*#4777*8665# yazın gelen menüden 2. seçeneği seçip geri ye basın işaret kaybolacaktır.
Tuş Seslerini Kapatmak:
Telefon Bekleme modundayken (kayar kapak açıkken) *#8999*8378# yazıyoruz
Karsınıza test modu diye menü geliyor,
Ordan '' 2. ''donanım testine giriyorsunuz,
Sona '' 2. '' ses ayarlarına giriyosunuz,
'' 1. '' Normal'e giriyoruz,
Aşağıda tuş sesi seviyesi var orayada girdikmi,
Düzey 1 yazan yeri (bende 64 tü) orayı 0 (sıfır) yapıp kaydedip çıkıyoruz... Artık tuş sesiniz kapalı güle güle kullanın...
NOT:Versiyon farklarından dolayı her telefonda aynı sonucu vermeyebilir....
güzel ve faydalı bir paylaşım elinize sağlık, teşekkürler. bir deneyelim bakalım nasıl bir sonuca ulaşacağız.
