Samsung F Series Smart TV (2013) App Store Change
With the arrival of the new Samsung F series Smart Tv's, brings a new key sequence to change the App store country.
Your TV must be connected to the internet in order for this to work, and be aware that in doing this your TV will reset to factory settings.
1. Set the TV to the "TV" source, press the source button and use the navigation pad select TV and then click to select.
147236
2. Open the Menu by pressing the Menu button.
147238
3. Use the navigational pad to select the "system" portion of the main menu, and then click to enter the sub menu.
147243
4. Setup will be selected by default, click to begin the setup. Note: If setup is greyed out you are not on the TV source, please return to step 1.
147245
5. You will begin the on-screen setup that you completed when you first bought the tv. Your previously entered information will be retained.
147247
6. Continue through the on-screen setup until you arrive at the Smart Hub Terms & Conditions, Privacy Policy page in the on-screen setup.
147250
7. With the Smart Hub Terms & Conditions, Privacy Policy page up on the TV press the following buttons in the sequence indicated.
147253
8. The country list will appear. Select your country from the list and then click continue.
147254
9. Complete the on-screen setup.
