Run my Application Only Once
To run your application only once (i.e. the first time the user inserts your CD-ROM, and no other time), place the following code in the On Startup event of your project:
--retrieve value from the registry. If the key does not exist, result = ""
result = Application.LoadValue("Application_Name", "First_Time");
--if there was no key, the program has never been run
if result == "" then
    Application.SaveValue("Application_Name", "First_Time", "yes");
    Dialog.Message("title", "this is the first time this program has run");
else
    Application.Exit();
end
Tip: You can also use Window.Close(Application.GetWndHandle(), CLOSEWND_TERMINATE) in place of Application.Exit(). This will close the window before the window draws itself (i.e. the user will see nothing).
