Rimu Schematic is professional quality electronic schematic capture software, designed for ease of use. Rimu Schematic follows familiar concepts and commands used in many other Windows applications. Presentation quality schematics – make a good impression on your employer or customers. Spice deck – run simulations of your schematic in any Spice compatible simulator. Abel and CUPL HDL – program PLDs by drawing the internal logic as a schematic. PCB Netlist – import into your PCB layout software for error-free PCB layout. Bill of Materials – import directly into your spreadsheet program. Supports OLE in place editing – insert diagrams, tables, equations, bitmaps and other objects into your schematic. Extensive printing options and print preview. Design rules checking. Heirarchical design with a Sub-circuit Wizard to automatically create sub-circuit symbols from schematics, or vice versa. Supplied with 2500 component library, which is expandable. Full text search on library component names and descriptions.
Easy to use, Rimu Schematic follows concepts you will be familiar with from other Windows based graphical applications.
Online context-sensitive help system.
Extensive printing and print preview options.
Hierarchical design with a Sub-circuit Wizard to automatically create sub-circuit symbols from schematics, or vice versa.
Twenty one libraries supplied containing more than 2000 devices and symbols.
Search libraries by part number and/or description.
New components and libraries can be created and edited easily.
Floating/drop down palettes of frequently used symbols speed up your work.
Snap to objects for easier drawing and wiring.
Windows MDI interface.
Multiple Undo / Redo command.
32 bit application runs under Windows 98, NT4.0, 2000 and XP operating systems.
Standard Edition – designs with up to 500 pins possible.
Professional Edition – design size limited only by available memory.
200MHz or faster CPU.
32Mb or more RAM.
At least 10Mb free hard disk space.
Windows 95, 98, NT4, 2000 or XP operating system.
32Mb or more RAM.
