100W RF power amplifier circuit built with 2 BLY94 transistors. If you want to see more rf amplifiers check the list bellow.
Components:
Active components: BLY94
Coaxial cable length : K x Lambda / 4, where K = 0.66 for 50 ohm cable and K = 0.8 for 75 ohm cable.
* L1 = L6 = 2 turns / 1.5mm / 14mm
* L2 = L7 = 8turns/0.8mm/4mm/ferite or HF
* L3 = L8 = 4 turns / 2mm / 14mm / gap 1mm
* L4 = L9 = 20turns/0.3mm / 3mm / ferite
* L5 = L10 = 1 turn / 2mm / 15mm
100W RF amplifier circuit diagram
Components:
