Positive Regulators 78xx series 3 Terminal Positive Voltage Regulator +5V until +24V1A 78Lxx series 3 Terminal Positive Voltage Regulator +5V until +24V 0.1A 78Mxx series 3 Terminal Positive Voltage Regulator +5V until +24V 0.5A 78Sxx series 3 Terminal Positive Voltage Regulator +5V until +24V 2A Negative Regulators 79xx series 3 Terminal Negative Voltage Regulator -5V until -24V 1A 3 Terminal Negative Voltage Regulator -5V until -24V 0.1A [95kb] Adjustable - General Voltage Regulators LM117 +1.2V...+37V 1.5A Positive Adjustable voltage Regulator LM217 +1.2V...+37V 1.5A Positive Adjustable voltage Regulator LM317 +1.2V...+37V 1.5A Positive Adjustable voltage Regulator LM137 -1.2V...-37V 1.5A Negative Adjustable voltage Regulator LM237 -1.2V...-37V 1.5A Negative Adjustable voltage Regulator LM337 -1.2V...-37V 1.5A Negative Adjustable voltage Regulator LM138 +1.2V to 32V output range. 5-Amp Adjustable Regulator LM338 +1.2V to 32V output range. 5-Amp Adjustable Regulator LM350 3-Amp Adjustable Regulator LM723 Precision Voltage Regulator L200 Positive variable voltage regulator supplies up to 2 A at 2.85 to 36 V.
Son düzenleme: 30 Eylül 2024
