Yeni sürümü yanınlana kadar uzun zaman geçti ancak Qunpack 2.2 yayımlandı. Dosyayı çalıştırınca bu ne kardeşim bu hangi dil demeyin, ortadaki menü tuşuna basıp seçin o dil seçeneği, oradan düzenleme yapabilirsiniz
The program is intended for fast (in a few seconds) unpacking of packers and simple protectors,
usually used to make software trial or limited by serial, using this (no past hacking knowledge needed),
you left with clean, fast and full software.
Quick Unpack tries to bypass all possible scramblers/obfuscators and restores redirected import. From the version 1.0 the opportunity of unpacking dll is added. From the version 2.0 the attach process feature added which allows to use Quick Unpack as a dumper and import recoverer. Scripts are also supported from version 2.0 which allows unpacking of more complicated protections. This makes Quick Unpack a unique software product which has no similar analogues in the world!
Use force unpacking tick. When the application is run QuickUnpack waits for the OEP breakpoint to trigger. But sometimes this breakpoint may be triggered several times but only the last one is the correct OEP. Using ForceMode option solves this problem. With this option after the application is run QuickUnpack counts breapoint hits and dumps the application only at the last stop. For DLL-files this option is always ticked and allows to restore relocs.
