Pegasus UPdate and News
Pegasus Box v1.0.7 is out! We have added support for a wide range of Samsung mobile phones.
Pegasus Box v1.0.7 Release Notes:
Added support for the following Samsung models:
  • Safe unlock codes reading/direct unlock for:
    • S8000
    • S8000H
    • S8000L
    • S8003
    • M8910
    • M8910B
    • M8910U
    • B2710
    • C5510H
    • S3370L
    • S3370B
    • S3370E
    • S5350
    • S5510T
    • S6700C
    • S6700T
  • Unlock codes reading/direct unlock/IMEI rebuild/flash reading and writing for:
    • T456
    • M2520
  • Direct unlock for:
    (unlock code reading was supported before already)
    • C5510
    • S3370
    • S5510
    • S6700
    • S6703
    • S5530
How to unlock the above listed models:
  1. Make sure that phone battery is fully charged.
  2. Power on phone without SIM card inside.
  3. Select "Samsung PC Studio" or "Samsung KIES" in "Setting" -> "Phone Setting" -> "PC Connections".
  4. Connect phone to computer via original USB cable.
  5. Wait until all drivers are installed.
  6. Click "Connect" button.
Download Pegasus Box v1.0.7
---------- Sonra gönderilen Saat 22:58 ---------- İlk önce gönderilen Saat 22:55 ----------
Pegasus Box v1.0.8 is out! We have added support for a wide range of Samsung mobile phones.
Pegasus Box v1.0.8 Release Notes:
  • C3510 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI (Use TAT MODE to perform these functions faster)/Read Full Flash/Write Flash.
  • C3530 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI/Factory Reset (Use Micro USB UART cable to perform these functions faster).
  • E1050 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI/Read Full Flash/Write Flash.
  • E1107 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI (Use TAT MODE to perform these functions faster)/Read Full Flash/Write Flash.
  • E1130b – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI/Read Full Flash/Write Flash.
  • E1170i – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI/Read Full Flash/Write Flash.
  • E2222 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI (Use TAT MODE to perform these functions faster).
  • E2370 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI/Read Full Flash/Write Flash.
  • E2530 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI/Factory Reset (Use Micro USB UART cable to perform these functions faster)/Read Full Flash/Write Flash.
  • S3350 – Read Unlock Codes/Read User Code/Direct Unlock/Rebuild IMEI/Factory Reset (Use Micro USB UART cable to perform these functions faster).
Download Pegasus Box v1.0.8
