WANT TO EDIT ANY OF THE EXE FILES AND CUSTOMIZE THE FONTS, STRINGS, IMAGE INSIDE THE EXE, HERE IS THE TOOL FOR YOU!!!
PE ExplorerPE Explorer gives you the power to look inside these PE binary files, perform static analysis, reveal a lot of information about the function of the executable, and collect as much information about the executable file as possible, without executing it.
PE Explorer leaves you with only minimal work to do in order to get an analysis of a piece of software. Once you have selected the file you wish to examine, PE Explorer will analyze the file and display a summary of the PE header information, and all of the resources contained in the PE file. From here, the tool allows you to explore the specific elements within an executable file.
Besides being an effective Resource Editor, PE Explorer also provides several tools that elevate it to Power Coder status: an API Function Syntax Lookup, Dependency Scanner, Section Editor, UPX Unpacker, and a powerful yet easy-to-use Disassembler. With PE Explorer you can view and inspect unknown binaries, examine and edit the properties of EXE and DLL files, and correct and repair the internal structures of any PE (portable executable) files with the click of a button. PE Explorer is intended to be used in various scenarios such as software development, forensics practice, reverse engineering, extensive binary security analysis and binary auditing processes.
With PE Explorer You Can
* See what's inside an executable and what it does
* Change and customize the GUI elements of your Windows programs
* Track down what a program accesses and which DLLs are called
* Understand the way a program works, behaves, and interacts with others
* Verify the publisher and the integrity of the signed executable files
* Say good bye to digging through bloated help files just to hash out an API reference
* Open UPX-, Upack- and NsPack-compressed files seamlessly in PE Explorer, without long workarounds
* Special support for Delphi applications
One Program, Many Tools
* PE Header and Section Viewer/Editor
* Fast Resource Viewer and Advanced Resource Editor
* Exported/Imported API Function List Viewer
* Disassembler
* Dependency Scanner
* Digital Signature Viewer
http://www.uydudoktoru.com/threads/pe-explorer-v1-99-r6-full.6610/
