OllyDbg 2.0 Beta 2 (updated 28-Mar-2009)
Please read it carefully before complaining:
1. OllyDbg 2.0 is rewritten from scratch.
2. No, plugins are not yet implemented.
3. Yes, they will be implemented again — presumably in v2.02.
The second beta. I've planned that it will come with the more or less complete help file. Unfortunately, I had no time to write it. Therefore there will be also the third beta release... soon.
There are many — over 20 — bugfixes in the beta 2, some of them are really critical. As promised, there are no significant changes, with two exceptions. The recognition of UNICODE strings is vastly improved, they are no longer limited to ASCII subset (option «Use IsTextUnicode ()». Also I recognize strings in the UTF-8 format. By the way, if you have some small sample program with the free source that uses UTF-8 strings, please send it to me (together with the screenshot of displayed strings) so that I will be able to test OllyDbg.
The second new feature is in the run trace. New option «Pause when EIP points to modified command» helps, for example, to find the real entry point of the SFX-ed code. Just don't forget to create backup first (or use another new option, Auto backup user code)!
Download OllyDbg 2.0 beta 2 (2138)
