D
doremon866
Guest
O&O AIO Software Mega Pack 2011
O&O AIO Software Mega Pack 2011 | 1.4GB
This release offers a collection of all programs of O&O Software. See next page for list of programs. EVERYTHING YOU NEED FOR YOUR HARD DISK/S FROM PARTITIONING, FORMATTING, DELETING, ERASING, DEFRAGMENTING, BACK-UP, RECOVERING AND SO MUCH MORE
The contents of the disk:
DiskImage
DiskRecovery
Defrag
CleverCache
PartitionManager
DiskStat
SafeErase
UnErase
DriveLED
RegEditor
Emergency Disk
O & O DiskImage Professional 5.5.126 x86 x64 (rescue disk) (Workstation, Server and Portable Version) 5.5.126 x86 x64
The program allows you to make images of entire hard drives and external hard drives or contained on these sections. Images obtained absolutely identical to the original, so it really can be used to restore the operating system rollback to a previous state of your computer and solving other similar problems. To prevent unintentional loss of data, many companies create images of systems and hard drives of all their network computers, and store them on high-end servers. Nevertheless, many employees are working, using their own laptops. Creating images of data and systems on a regular basis, save from annoying accidents, and help you avoid downtime or time-consuming restorations!
O & O Defrag Pro 14.1.431 x86/x64 EN / RU Portable Pro 14.1.431 x86/x64 RU O & O Defrag Server v14.1.305 x86 x64 O & O Defrag Workstation.v14.1.305
Allow you to regain the performance workstations Windows.
The solution of O & O Defrag eliminate the fragmentation of files and arrange them in order. Now the operation of reading and writing data will be faster, have a positive impact on system performance in general. Defrag offers a wide selection of new and unique features that make it extra effort to optimize your system.
O & O CleverCache Professional v7.1.2737 x86.x64 O & O CleverCache Professional Edition 7.1.2787 Portable
This is a unique tool to optimize the operations related to caching of files in the operating systems Windows Vista, NT, 2000, Windows XP? 2003 Server and 2008 Server. CleverCache translates as "smart cache".
O & O SafeErase 4.1 Build 153 RUS x86 x64 O & O SafeErase 4.1.103 x86x64 Portable
When you sell your hard drive from your old computer, you know that the data on it is almost never completely removed. Even when the hard disk is formatted, anyone can simply restore the data using the software and easily available information such as your database of clients, building plans or your passwords. Fact: The data is deleted in Windows easily recover again.
O & O DriveLED Pro 4.1.57 (32 Bit 64 Bit)
The program for tracking the status of hard drives. Monitoring the status of hard drives is using the technology of SMART, and in case of any problems with the "health" of your diskoa, DriveLED instantly notify you. Thus, due to DriveLED, you will be protected from possible loss of important information, and if the hard disk will get worse, then you can quickly make a backup of important files to a possible critical disk crash.
O & O DiskRecovery 6.0.6298 (x32 x64 Bit) Portable O & O DiskRecovery 6.0.6298
Functionally, begins where other programs are baffled.
This software combs every sector of the hard drive, memory card or digital camera cards for the presence of lost files.
Even if the file system is formatted or destroyed, this program can reconstruct data that was once removed. The program supports over 300 file types, including documents MS Word, Excel, Access, image files, music and video (JPEG, AVI, MPEG, MP3, WAV, BMP, TIFF, Corel Draw, Photoshop, Framemaker, Adobe Illustrator). You no longer have to suffer and to reinstall the entire system and all applications in the event of losing important files! O & O DiskRecovery very easy to work, the interface is clear even to a child, and the procedure for scanning drives for deleted files - it is generally the main advantage of the developers.
O & O MediaRecovery Pro 6.1.6182 32 64 bit O & O MediaRecovery 6.0 Build 6312
The program is designed to recover audio, video and image files on removable media, media players and digital cameras. The program implemented additional algorithms for data retrieval, an expanded list of supported file formats and functions for working with media images created in the program O & O DiskImage.
O & O PartitionManager 3.0 Build 199 Professional Edition (x32 x64)
The program is new and advanced tool for working with your hard drives. With this program you can split the hard drive into partitions, resize and move disks to other places. The program is designed in such a way that is similar to standard Windows Disk Manager, but, unlike him, includes a number of advanced features such as resizing partitions or transfer titles to a new location. It is also worth noting that the program supports all types of discs, ranging from hard drives, and finishing with the USB stick and memory card, which can also be divided into sections, etc. The program interface is simple and easy to use.
O & O DiskStat Professional (32 64 Bit) Server Editions v2.0.320 (32 64 Bit)
Powerful program for a full analysis of all available files and folders on your hard drive. With its easy-to-use interface, you can see the file and folder structure of internal and external drives. Often, after a long use of the operating system, the disk is going to many different files that in total you will never need, but take a lot of places that could be used for more specific goals and objectives. For such cases, and was designed this program to help you figure out which folder or file, how many took place and what files should be removed, so that would free up disk space. Professional version is designed for use on home computers, while the server version is perfect for use on servers.
O & O RegEditor 1.0.3045
Program Registry Editor Windows. O & O RegEditor provides full access to the registry database Windows. Settings for many applications, Windows, drivers and services.
O & O UnErase 6.0.1899 (32 64)
The program, which allows you to save critical files that were deleted from the hard drive as a result of the virus, due to an error in the application or simply through negligence. O & O UnErase Recover data even in cases where it seems impossible. Application differs utmost simplicity to use and works on computers running operating systems, Windows NT, Windows 2000 or Windows XP. If you delete important files, without bothering to create their backups, just run the application UnErase, which quickly detects lost data on hard disk and restore them.
Mirror 1:
DiskImage
DiskRecovery
Defrag
CleverCache
PartitionManager
DiskStat
SafeErase
UnErase
DriveLED
RegEditor
Emergency Disk
http://www.filesonic.com/file/1293310904/OOSoftwarePack.2011.part1.rar
http://www.filesonic.com/file/1293313164/OOSoftwarePack.2011.part2.rar
http://www.filesonic.com/file/1293317604/OOSoftwarePack.2011.part3.rar
http://www.filesonic.com/file/1293320244/OOSoftwarePack.2011.part4.rar
http://www.filesonic.com/file/1293337474/OOSoftwarePack.2011.part5.rar
http://www.filesonic.com/file/1293313654/OOSoftwarePack.2011.part6.rar
Mirror 1:
http://www.fileserve.com/file/7JajytA/OOSoftwarePack.2011.part1.rar
http://www.fileserve.com/file/rzeSDzh/OOSoftwarePack.2011.part2.rar
http://www.fileserve.com/file/j8Q2YWH/OOSoftwarePack.2011.part3.rar
http://www.fileserve.com/file/UW8Mp75/OOSoftwarePack.2011.part4.rar
http://www.fileserve.com/file/sXrMN5X/OOSoftwarePack.2011.part5.rar
http://www.fileserve.com/file/DwFw5Kc/OOSoftwarePack.2011.part6.rar
