Nokia LCD Pinouts
uydudoktoru
Yönetici
Yönetici
5110 / 5130 / 6110 / 6150
LPH 7366 Pinouts (front view)
  • Lcd chip controller: Philips PCD8544 /Seiko Resolution: 84x48, B/W Technology: FSTN Spare part code: 4850113
pin1 V+ 2.7V to 3.3V pin2 Sclk pin3 Sda pin4 DorC pin5 Cs pin6 Osc (32768Hz from external clock, not used; this lcd works fine with internal osc ) pin7 Gnd pin8 Vout(DC/DC voltage converter) pin9 Reset
3210 / 3310 & 3330
LPH7779, LPH7677 Pinouts (front view)
  • Lcd chip controller: Philips PCD8544 Resolution: 84x48, B/W Technology: FSTN Spare part code: 4850123 for 3310 & 3330
pin1 V+ 2.7V to 3.3V pin2 Sclk pin3 Sda pin4 DorC pin5 Cs pin6 Gnd pin7 Vout(from internal DC/DC voltage converter) pin8 Reset
Link: How to drive a Nokia LCD, type LPH7779, LPH7677 or LPH7366 with PIC16F84A
3410
  • Lcd chip: Philips OM6206 (102x65) !!! lcd panel it's connected to center 96 columns of lcd driver Resolution: 96x65 , B/W Technology: FSTN Spare part code: 4850335
Pin1 Vdd Pin2 Sclk Pin3 Sdata Pin4 D/_C Pin5 _Sce (enable) Pin6 Gnd Pin7 Vlcd Pin8 _Reset 7110
Nokia7110 LCD Module
  • Lcd chip controller: Seiko-Epson SED1565 (132x65) now S1D15605, search for s1d15000tm.pdf ; !!! lcd panel it's connected to center 96 columns Resolution: 96x65, B/W Technology: FSTN Spare part code: P313032901
pin1 Temp sensor 47k (at 25C) pin2 _CS pin3 Speaker_p pin4 D/_C pin5 SCLK (max. 3.2MHz at Vlogic=+2.8V) pin6 Speaker_n pin7 On/Off pin8 Led - pin9 Led + pin10 Gnd pin11 Gnd pin12 Vlogic (+ 2.8V) pin13 SDATA pin14 _RESET
Link: How to interface a Nokia 7110 lcd with PIC16F84
3510i
Nokia 3510i LCD Module
  • Lcd chip controller: Epson S1D15G14 Datasheet Resolution: 98x67 , 4096 colours Technology: CSTN Spare part code: 4850331
3510
Nokia 3510 LCD Module
  • Lcd chip controller: Seiko-Epson (thickness 2,7 mm) or Philips (thickness 1,7 mm) Resolution: 96x65 , B/W Technology: FSTN Spare part code: 4850247
Pin1 _Reset Pin2 _Cs Pin3 Gnd Pin4 Sdata Pin5 Sclk Pin6 Vio 1.8V Pin7 Vbooster in 2.7V Pin8 Vlcd max.12VLink: Avr basic code
Nokia 6310
Nokia 6310 & 6310i lcd pinouts
  • Lcd chip: Philips pcf8511 / pcf8813 (I think - not tested but it looks to be the same lcd driver used in N3510) Resolution: 96x65 Protocol: SPI 3Wire Die size: cca. 2,85x10,85 mm Spare part code: 4850163
Pin8 _Reset Pin7 _Cs Pin6 Gnd Pin5 Sdata Pin4 Sclk Pin3 Vio 1.8V Pin2 Vbooster in 2.7V Pin1 Vlcd (from internal dc/dc converter)
2100
Nokia 2100 LCD Module with a Samsung controller
  • Lcd chip controller:Samsung (green) , Seiko-Epson (red) or Philips (blue) Resolution: 96x65 , B/W Technology: FSTN
Pin1 VBB 2.8V Pin2 Sclk Pin3 Sdata Pin4 Data/_Control Pin5 _ChipSelect Pin6 Gnd Pin7 Vlcd out (+9V) Pin8 _Reset
8310
Nokia 8310 lcd pinouts
  • Lcd chip: OM6211 Resolution: 84x48 Technology: FSTN Spare part code: 9490306
3109 / 3110 / 3500 Classic
Lcd connector
  • Lcd chip controller: SPFD54124 from Orise Technology Resolution: 128x160, 262k colours Technology: TFT Spare part code: 4851057 / 4851058 / 4850080
1,4,16,21,24 Gnd 2 Vled- 3 Vio 5 Wrx 6 D0 7 P/Sx 8 D2 9 D4 10 D6 11 Csx 12 Resx 13 Te 14 D7 15 D5 17 D3 18 D1 19 D/Cx_Scl 20 Rdx 22 Vdd 23 Vled+
1680 Classic / 2600 Classic / 2630 / 2660 / 2760
Nokia 2630 lcd connector
  • Lcd chip controller: SPFD54124 Resolution: 128x160, 65k colours Technology: TFT Spare part code: 4850174 / 4850175/ 4851035
1,4,5,7,8,9,10,14,15,16,17,18,20,21,24 Gnd 2 Vled- 3 Vio 6 Sda 11 Csx 12 Resx 13 Te 19 Scl 22 Vdd 23 Vled+
  • Chip size: SPFD54124A 13.5x0.85mm SPFD54124B 13.5x0.70mm SPFD54124C 9.9x0.67mm
Download the SPFD54124B datasheet.
Some photos with Nokia 2760 lcd received from David:
