MXKEY,MXbox,v3.5 revision 1.2, MAJOR UPDATE
MXKEY,MXbox,v3.5 revision 1.2, MAJOR UPDATE - The only BOX with TMA included
v3.5 revision 1.2, Public-Release MAJOR UPDATE
What is new:
MAIN
- Added, Files synchronization feature
- Allows to check and update important files with server without installing full setup.
- Also useful to minimize problems because of users patch.
- Fixed, Access violation on XP for PC without HTI(WinUsb) installed
- Check For updates and Single module update removed(replaced with Synchronize Files)
NK(Nokia Service Tool)
- Added, optional SX5 serial used for SL3 NCK calc (*)
(*) required HTI firmware version 00.17 or later
- Added, Latest flash update definition to setup
- Added, Options to disable/enable RAPIDO new protocol for USB flashing
- Added, Options to disable/enable embedded SBL for XGOLD flashing
- Added, HTI SoftTMA Resistor selection (*)
- Added, Local storage definition for DCC and RFBB data.
- Added, DCC data verify after write
- Improved, DCC data write (If DCC write fail, DATA will be written as PM)
- Fixed, Download in background deadlock bug
- Fixed, PM erase bug (was early stopped on newer BB5 phone)
- Fixed, DCT4 flashing
- Fixed, New ProductProfile write
QCD(CDMA Service Tool)
- updated patch definition to version 1.4
- added unlock definition for: Haier Q9+-INAV1.04-100326-JWD, method: patch unlock
- added unlock definition for: ZTE SM_C36X_RBTL05NV1.0.0B05, method: direct unlock (not tested!)
- fixed unlock definition for: ZTE TM_S189_RBTL35NV1.0.2B01, method: direct unlock
- fixed unlock definition for: ZTE TM_S168_RBTL35NV1.0.0B02, method: direct unlock
- see "modules\{9A05071F-D3A6-484B-8E3E-C6F47311C78C}\supported_phones.txt" for list supported models
BB (BlackBerry Tool)
- Added, Factory lock status on device scan
- Minor bug fixes
420 Links to download MxBox/MxKey v3.5 rev1.2 for FREE
1. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
2. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
3. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
4. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
5. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
6. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
7. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
8. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
9. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
10. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
11. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
12. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
13. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
14. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
15. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
16. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
17. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
18. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
19. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
20. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
21. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
22. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
23. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
24. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
25. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
26. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
27. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
28. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
29. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
30. 14 links for mobileEx_setup_v3.5_rev1.2_20110624.exe
