O
omega
Guest
Mentor Graphics Precision RTL 2011a.61 x86 2011 + Crack
Mentor Graphics Precision RTL 2011a.61 x86 2011 + Crack | 398MB
Means of synthesis of high-performance FPGA-type PLD and FPGA, optimized in terms of ease of use and high quality results. Supports a multi-million-programmable systems-on-Chip (FPSoC) the last generation.
Precision RTL Synthesis receive input on the project as a description in VHDL or Verilog and implements logic synthesis with the defined limits, based on built-in libraries of manufacturers. The package has a built-in static timing analysis, the ability to analyze and debug in an incremental mode, and an intuitive user interface makes it easy to manage the process of fusion as an experienced engineer, and beginner. Precision RTL Synthesis includes a unique optimization algorithm - Architecture Signature Extraction (ASE), which automatically selects the most critical in the project area, limiting the overall system performance, such as finite automata, logical paths between the various levels of design hierarchy or logical path with a very large number of combinational logic . ASE algorithm uses heuristic analysis in an automatic mode to reduce the size of the project and increase its productivity without the need for manual intervention. It supports all series of crystals Xilinx (including the Virtex-7), Altera, Actel and Lattice.
Year / Date of Release: 2011
Version: 2011a Build 1961
Developer: Mentor Graphics
Bit depth: 32bit
Compatibility with Vista: complete
Compatible with Windows 7: complete
Language: English
Filesonic.com Fileserve.com Rapidshare.com Hotfile.com
I will check, If link die, I will reupload at here
Download Filesonic
Bit depth: 32bit
Language: English
http://tinypaste.com/a31068
Download Filesonic
http://www.filesonic.com/file/1224855044/Precision.part1.rar
http://www.filesonic.com/file/1224855074/Precision.part2.rar
http://www.filesonic.com/file/1224860844/Precision.part3.rar
http://www.filesonic.com/file/1224860814/Precision.part4.rar
