Make an Image Semi-Transparent
In AutoPlay Media Studio, it is possible to make an image object translucent, or "see-through." This is accomplished by lowering the value of the Opacity setting in the properties pane:
  1. Create an image object
  2. In the properties pane, change the Opacity setting to the desired opacity.
Note: The opacity number is a percentage. A value of 100 makes the object fully visible, and a value of 0 makes the object invisible.
