KAZANÇ KONTROLLÜ OPAMP (GAIN CONTROLLED OPAMP)
The gain controller uses a 4066 quad bilateral switch to electronically select a feedback resistor for the 741 op amp. One or more switches can be turned on at the same time to produce a stepped, variable-gain range from less than 1 to 100.
Yazar: guclusat
Makale başlığı: KAZANÇ KONTROLLÜ OPAMP (GAIN CONTROLLED OPAMP)
