H
haingoc
Guest
JetBrains TeamCity Enterprise 6.5 [All Windows]
JetBrains TeamCity Enterprise 6.5 [All Windows] | 617 MB
TeamCity is a continuous integration & build management solution which, following the tradition of IntelliJ IDEA, takes software team productivity to a whole new level.
It automates and coordinates key collaborative processes to eliminate manual systems and delays, providing tight integration with multiple build and test tools, real-time unit test frequency, server-side inspections and code coverage analysis. TeamCity is a continuous integration and build management system. With TeamCity, you can set up a build server within minutes and enjoy out of the box continuous unit testing, code quality analysis, and early reporting on build problems - even without leaving your favorite IDE. TeamCity offers a gentle learning curve, so you can quickly improve your release management practices by gradually adopting its advanced features and capabilities.
Build Grid uses a computing grid to run parallel builds on multiple Build Agents with different platforms
Amazon EC2 integration for rapid Build Grid scaling
Pre-tested commits help avoid breaking the code in the repository and optimize the code integration cycle
On-the-fly test results reporting with intelligent tests re-ordering
Build configuration templates for easier builds replication
Over 600 automated server-side inspections for Java, JSP, javascript and CSS
Comprehensive server configuration and Build Grid management console
Role-based, per-project user administration with user groups support
LDAP support with automatic user profile synchronization Assigning and taking responsibility over the broken builds
Configurable per-user and per-user group notifications
Detecting hanging builds, with a thread dump to help investigate the cause
Customizable statistics on build duration, success rate, code quality and custom metrics
Change history browsing with a Diff Tool and "History" builds
Integration with issue tracking systems: JIRA, Bugzilla and JetBrains YouTRACK out of the box, more with 3rd party plugins
Dedicated support for Maven and Gradle build systems
Integrated code coverage and duplicates finder for Java and .NET
Integration plugins for most major IDEs with automatic navigation between the web browser and your IDE
Support for .NET, Java and Ruby
What's New in TeamCity 6.5
Less restrictions in Professional Edition
Remote run on changes in DVCS branches
Enhanced Build Parameters
Parameterized Version Control System roots
Project-level parameters
Parameters completion
Parameters of a build
Restyled web interface
Tests grouping
Test failures muting
Responsibility renamed to Investigation
Reworked My Changes page
Audit of project configuration changes
Build steps
Agents
Agents JVM upgrade
Remote build agent installation
Agents parameters report
Amazon Elastic Cloud integration improvements
IDE integration
VS-addin integrates with JetBrains dotCover 1.1
Filtering of data by current project
Tests grouping
Build steps
Agents
Agents JVM upgrade
IDE integration
http://www.filesonic.com/file/1158344344/JetB...ker-EMBRACE.rar
http://www.filesonic.com/file/1158344354/JetB...ker-EMBRACE_2.rar
