1. Set the TV to the TV source, press the source button and use the navigation pad, select TV and then click to select.
2. Open the Main Menu.
3. Use the navigational pad to select the System portion of the Main Menu, and then click to enter the sub menu.
4. Setup will be selected by default, click to begin the setup.
5. You will begin the on-screen setup that you completed when you first bought the television. Your previously entered information will be retained.
6. Continue through the on-screen setup until you arrive at the Smart Hub Terms & Conditions, Privacy Policy page in the on-screen setup.
7. With the Smart Hub Terms & Conditions, Privacy Policy page up on the TV press the following buttons in sequential order.
Mute Return Vol + CH ∧ Mute
8. The country list will appear. Select your country from the list and then click to continue.
9. Complete the on-screen setup. You TV's country code has now been changed.
Resimli anlatımı ektedir
