How To Completely Turn Off the vBulletin Archive
Step 1: Turning the archive off is relatively easy, first we start with vBulletin itself:
  • Visit your vBulletin Admin Control Panel, and on the left hand side, go into vBulletin Options.
  • In the dropdown, find Search Engine Friendly Archive.
  • Set the first option (Forum Archive Enabled) to "No", and hit the "Save" button.
Step 2: Now we want to change a few vBSEO Settings, in order to stop the rewrite:
  • Go into your vBSEO Control Panel (vbseocp.php) from your web browser and find the setting group called vB's Archive Options.
  • For the first drop down option, select Keep vB's Archive default settings.
  • Then hit the "Save Settings" button to proceed (Remember to have your config_vbseo.php CHMOD to at least 666)
Step 3: Disable search engines from indexing archive:
  • Inside of your robots.txt, you should add the following lines to the bottom. (If you had a custom location for your archive, then please add that just like the following)
    • Disallow: /sitemap/
    • Disallow: /archive/
Step 4: Disable archive from sitemap (If you have our vBSEO Sitemap Generator installed, proceed, if not, then you are finished)
  • In the dropdown, find vBSEO Google/Yahoo Sitemap Generator.
  • Find option Include Archive Pages and set it to No.
Step 5: Remove the sitemap links in footer
  • Go into your vBSEO Control Panel (vbseocp.php) from your web browser and find the setting group called vBSEO Footer Archive Links.
  • In the dropdown, select the Do not add Links to Archive Pages option, then hit the save settings button
